| RFoulds |
Mar 29 2024, 03:14 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 861 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
Finally installing my oil lines and the sandwich adaptor is thicker than my old one I think. Using a Derale oil filter adaptor, model no. 15702. this is making my stock Mahle filter OC28 hang down too far and the engine mount bar is in the way.
Has anyone found a shorter filter to use? |
| bdstone914 |
Mar 30 2024, 11:24 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,283 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Rfoulds
You need to look for a filter with a 3/4-16 thread size, oring close in diameter and thickness, oil pressure relief around 8-12 lbs and have the anti drainback rubber flap over the inlet holes. Fram makes crap filters but there site had good data. Once you find a workable filter most manufacturers have cross references to other brands. |
RFoulds need shorter oil filter for sandwich Mar 29 2024, 03:14 PM
Geezer914 I use K&N 2004 oil filters. Mar 29 2024, 03:21 PM
RFoulds looks like that is same size and length. Do you kn... Mar 29 2024, 03:51 PM
ClayPerrine The filter for a 1979 924 fits and is physically s... Apr 1 2024, 08:39 AM
TheCabinetmaker
The filter for a 1979 924 fits and is physically ... Apr 9 2026, 05:49 PM
Geezer914 I have a Mocal unit. Apr 1 2024, 10:16 AM
Geezer914 The filter for the 924 is around 5" long so i... Apr 1 2024, 12:58 PM
RFoulds Thanks everyone. Discovered that my issue was tha... Apr 3 2024, 09:37 AM
Alapone
Thanks everyone. Discovered that my issue was th... Apr 15 2024, 09:15 AM
914werke
The filter for the 924 is around 5" long so ... Apr 9 2026, 02:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 07:04 PM |
