vacuum issue, won't run, mechanic needs help |
enf2232 |
Apr 1 2024, 12:56 PM
Member Group: Members Posts: 86 Joined: 13-July 14 From: Toledo, OH Member No.: 17,621 Region Association: None |
Background: 1.7 liter which has been upgraded with new pistons and cylinders, original fuel injection. Car started and ran, then stalled and would not restart. Covid hit so it sat for a while. Now at mechanics shop where they have replaced the fuel pump (rebuilt original) and the manifold pressure sensor (rebuilt).
Engine has low manifold vacuum, 10-12" and will not start. If they apply 15-18" of vacuum with a vacuum pump it starts right up and will run fine for 20-30 minutes (on pump), then stalls. If they attempt to restart, it backfires and will not restart until cold. Any suggestions on what to check or what next step should be? |
76-914 |
Apr 1 2024, 03:09 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Do as previous post suggested and have mechanic do a smoke test on the vac system. Who rebuilt the MPS? Was it calibrated for your engine? Did they do a vacuum test on the MPS?
Lo-Fi Version | Time is now: 3rd June 2024 - 10:29 AM |
