5 lug rear rotors |
5 lug rear rotors |
jmargush |
Mar 25 2024, 04:18 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Are the 5 lug rear rotors supposed to use the 2 small screws to mount them to the hub or does the wheel just hold them to the hub?
Attached thumbnail(s) |
Eric_Shea |
Apr 1 2024, 04:25 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Are the 5 lug rear rotors supposed to use the 2 small screws to mount them to the hub or does the wheel just hold them to the hub? The Hub is a URO hub which has the 911 mounting hole pattern. The Rotor is a 914-4 redrill and the mounting hole pattern is the 914 pattern. Solutions: 1. Redrill the hub to the 914-4 mounting hole pattern. 2. Redrill the rotor to the 911 mounting hole pattern. 3. Set your handbrake by using two open faced lug nuts then, install your wheels as @JamesM mentions and forget about it. 4. Purchase 914-6 rear rotors?? |
Lo-Fi Version | Time is now: 1st June 2024 - 11:27 AM |
