> 1976 fuel injection questions
914incali
post Apr 2 2024, 11:07 AM
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican
Karl R
post Apr 3 2024, 07:04 PM
Also that is the wrong FI for your car. Your 1976 car should have a L jet instead of that D jet. Personally I prefer the L jet anyhow since it is quite a bit more mechanically robust in terms of all the connectors and wiring. I think the manifolds will have holes for three studs buy your heads will have four.
JeffBowlsby
post Apr 3 2024, 07:23 PM
QUOTE(Karl R @ Apr 3 2024, 06:04 PM) *
Um, no. 1976 914 2.0L GC code engines are DJet, 3 stud heads. The 912E is LJet maybe that’s what you are thinking about.
914incali   1976 fuel injection questions   Apr 2 2024, 11:07 AM
dr914@autoatlanta.com   power is from the relay board in the engine compar...   Apr 2 2024, 11:18 AM
914incali   I have a complete injection system and am waiting ...   Apr 2 2024, 11:34 AM
rjames   Black and red= power, brown=ground to chassis.   Apr 2 2024, 11:54 AM
914incali   Black and red= power, brown=ground to chassis. ...   Apr 2 2024, 12:12 PM
JeffBowlsby   Single brown ground cable for the fuel pump is se...   Apr 2 2024, 01:15 PM
914incali   yes its out of a 73 2.0, im not to worried about s...   Apr 2 2024, 01:31 PM
fiacra   yes its out of a 73 2.0, im not to worried about ...   Apr 2 2024, 10:02 PM
L-Jet914   yes its out of a 73 2.0, im not to worried about ...   Oct 10 2024, 11:33 PM
burton73   The problem is you are in California, and you need...   Apr 2 2024, 01:39 PM
Karl R   Also that is the wrong FI for your car. Your 1976...   Apr 3 2024, 07:04 PM
JeffBowlsby   Also that is the wrong FI for your car. Your 197...   Apr 3 2024, 07:23 PM
wonkipop   Also that is the wrong FI for your car. Your 19...   Apr 4 2024, 06:10 PM
Ron914   [quote name='JeffBowlsby' post='3137731' date='Ap...   Oct 9 2024, 12:42 PM
wonkipop   [quote name='JeffBowlsby' post='3137731' date='A...   Oct 9 2024, 04:15 PM
L-Jet914   [quote name='JeffBowlsby' post='3137731' date='A...   Oct 10 2024, 11:17 PM
r_towle   76 is djet. I happen to have one here if you need...   Apr 3 2024, 08:23 PM
Karl R   I guess I'm starting to slip. I thought they s...   Apr 4 2024, 04:39 PM
r_towle   I guess I'm starting to slip. I thought they ...   Apr 4 2024, 05:31 PM
JeffBowlsby   For smog purposes CA-only model 1975-76 914s also ...   Oct 9 2024, 05:15 PM
wonkipop   @Ron914 here is what CARB would have on file for...   Oct 9 2024, 08:06 PM
Ron914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 10 2024, 04:58 PM
wonkipop   well i can only speak as an australian down here...   Oct 10 2024, 06:57 PM
fiacra   [quote name='wonkipop' post='3172034' date='Oct 9...   Oct 10 2024, 11:14 PM
Ron914   [quote name='wonkipop' post='3172034' date='Oct ...   Oct 10 2024, 11:47 PM
L-Jet914   [quote name='fiacra' post='3172200' date='Oct 11 ...   Oct 10 2024, 11:57 PM
wonkipop   [quote name='fiacra' post='3172200' date='Oct 11 ...   Oct 11 2024, 12:41 AM
JeffBowlsby   Did paperwork from the previous smog tests come wi...   Oct 10 2024, 05:28 PM
wonkipop   on the question of how the previous owner got the ...   Oct 10 2024, 07:07 PM
wonkipop   @JeffBowlsby you always throw up interesting inf...   Oct 10 2024, 07:22 PM
JeffBowlsby   Yes! It’s in the Service &Training manu...   Oct 10 2024, 07:48 PM
JeffBowlsby   I have at least one 75 CA 2.0L with the SL box on ...   Oct 10 2024, 07:58 PM
wonkipop   I have at least one 75 CA 2.0L with the SL box on...   Oct 10 2024, 09:44 PM
JeffBowlsby   [quote name='JeffBowlsby' post='3172179' date='Oc...   Oct 10 2024, 10:15 PM
wonkipop   [quote name='JeffBowlsby' post='3172179' date='O...   Oct 11 2024, 12:38 AM
Ron914   When I bought the car I had to go to the DMV and p...   Oct 10 2024, 10:47 PM
L-Jet914   If you have a plate number you can see the pass/fa...   Oct 10 2024, 11:03 PM
L-Jet914   Everything required for a California certified 197...   Oct 10 2024, 11:28 PM
wonkipop   Everything required for a California certified 19...   Oct 11 2024, 12:39 AM
930cabman   Glad I don't live in Cali   Oct 11 2024, 05:04 AM
fiacra   Glad I don't live in Cali It ain't bad ...   Oct 11 2024, 03:29 PM
emerygt350   Absolutely agree. Drives me crazy living in NY tr...   Oct 11 2024, 06:35 PM
davep   So Ron, what is the current situation?   Jan 5 2025, 03:30 PM
fiacra   @914incali [b]@[url=http://www.914world.com/bbs2...   Jan 5 2025, 03:57 PM
Ron914   Thanks for checking in . I am still working on my ...   Jan 6 2025, 12:28 PM
Ron914   I believe it was @ emerygt350 that asked @slapsho...   Jan 6 2025, 12:35 PM
JeffBowlsby   Post a photo of that oblong hole so we clearly und...   Jan 6 2025, 12:48 PM
rjames   Post a photo of that oblong hole so we clearly un...   Jan 6 2025, 02:02 PM
emerygt350   If the idle adjust screw no longer closes off the ...   Jan 6 2025, 02:54 PM
Ron914   I would really like to post a photo or video but l...   Jan 6 2025, 04:44 PM
burton73   I would really like to post a photo or video but ...   Jan 6 2025, 06:19 PM
Ron914   [quote name='Ron914' post='3185256' date='Jan 6 2...   Jan 6 2025, 06:37 PM
burton73   Sending this to Rick as well. You are very close...   Jan 6 2025, 09:28 PM
emerygt350   You are all good with that butterfly. That is how...   Jan 6 2025, 06:08 PM
Ron914   You are all good with that butterfly. That is ho...   Jan 6 2025, 07:04 PM
technicalninja   Thanks Bob!   Jan 7 2025, 09:20 AM
rjames   The butterfly should have two screws that hold t...   Jan 7 2025, 11:05 AM
emerygt350   The butterfly should have two screws that hold ...   Jan 7 2025, 12:47 PM
Ron914   The butterfly should have two screws that hold...   Jan 7 2025, 02:34 PM
emerygt350   At the current state I would leave it in the hole,...   Jan 7 2025, 07:56 PM
Ron914   Hello , I covered the inside idle screw air intake...   Jan 11 2025, 06:12 PM
emerygt350   Great news. What a nice looking car! Just ou...   Jan 11 2025, 07:18 PM
Ron914   Great news. What a nice looking car! Just o...   Jan 11 2025, 08:00 PM
fiacra   Good luck on Monday. Fingers crossed. If it does...   Jan 11 2025, 07:41 PM
JeffBowlsby   You might also try a smoke pen/pencil. Lower inve...   Jan 11 2025, 08:48 PM
emerygt350   Is your vacuum retard can on the distributor hooke...   Jan 11 2025, 09:24 PM
Ron914   Is your vacuum retard can on the distributor hook...   Jan 12 2025, 09:23 AM
Ron914   Lets try the photo again   Jan 12 2025, 09:39 AM
JeffBowlsby   Hose 10 is not connected to anything on a 1974-76 ...   Jan 12 2025, 09:53 AM
Ron914   Hose 10 is not connected to anything on a 1974-76...   Jan 12 2025, 10:22 AM
Ron914   I don't think that this is the source of my va...   Jan 12 2025, 10:23 AM
Ron914   should the #10 hose be plugged or left open to air...   Jan 12 2025, 10:24 AM
Ron914   should the #10 hose be plugged or left open to ai...   Jan 12 2025, 10:32 AM
rjames   [quote name='Ron914' post='3186354' date='Jan 12 ...   Jan 12 2025, 12:54 PM
Ron914   When I first assembled my motor I followed this di...   Jan 12 2025, 10:40 AM
Ron914   When I first assembled my motor I followed this d...   Jan 12 2025, 10:56 AM
emerygt350   We should walk you through all the vacuum hoses. ...   Jan 12 2025, 02:02 PM
emerygt350   We should walk you through all the vacuum hoses. ...   Jan 12 2025, 02:05 PM
Ron914   We should walk you through all the vacuum hoses....   Jan 12 2025, 02:58 PM
rjames   ‘75/76 2.0 cars did not have the PCV valve.   Jan 12 2025, 02:37 PM
emerygt350   ‘75/76 2.0 cars did not have the PCV valve. ...   Jan 12 2025, 03:50 PM
emerygt350   And... That decel keeps you from blowing out your ...   Jan 12 2025, 03:54 PM
JeffBowlsby   Good point that this is a ‘76 car, the 75-76 car...   Jan 12 2025, 07:32 PM
Ron914   Hi Jeff , Yes ,as I mentioned I have a federally c...   Jan 12 2025, 08:04 PM
emerygt350   They were always trying different things to handle...   Jan 12 2025, 08:31 PM
Ron914   They were always trying different things to handl...   Jan 12 2025, 08:40 PM
emerygt350   Anyone got a good 76 vacuum map? I am always nerv...   Jan 12 2025, 08:33 PM
Ron914   The exciting thing for me is we believe this is a ...   Jan 12 2025, 08:54 PM
Ron914   Hello @914incali I also have a 76 914 I am tryin...   Jan 12 2025, 09:40 PM
Ron914   @emerygt350 I think this will be my last post in ...   Jan 14 2025, 09:35 AM
emerygt350   Yes, probably a good idea. But you know now that ...   Jan 14 2025, 03:36 PM
Ron914   Yes, probably a good idea. But you know now that...   Jan 14 2025, 04:18 PM
emerygt350   Your car doesn't have an advance port, that wo...   Jan 14 2025, 04:30 PM
emerygt350   If you have your advance hose hooked to any kind o...   Jan 14 2025, 04:32 PM
Ron914   If you have your advance hose hooked to any kind ...   Jan 14 2025, 08:24 PM
emerygt350   That is good news. Progress! I will wait for...   Jan 15 2025, 06:25 AM
brant   Please don’t “Time by ear” Remark the timi...   Jan 15 2025, 10:53 AM
Ron914   Please don’t “Time by ear” Remark the tim...   Jan 15 2025, 11:28 AM
914werke   I started updating this one based on an unmolested...   Jan 15 2025, 11:17 AM
Ron914   I started updating this one based on an unmoleste...   Jan 15 2025, 12:30 PM
- Lo-Fi Version Time is now: 15th November 2026 - 02:50 AM
