Dry sump leakdown prevention? |
gnomefabtech |
Mar 25 2024, 11:02 AM
Member Group: Members Posts: 111 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Hello!
So I'm running a dry-sump system on my 'teen and it's all great except if the car sits for a few days the oil in the tank slowly fills the motor. This wouldn't be a big deal except it floods the turbo and then there's smoke. So much smoke. Does anyone have experience using a low cracking pressure check valve to hold the oil in the tank until the car is running? I see a selection of these on McMaster but I'm understandably nervous about restricting the flow into the engine from the tank. It's a -12 an line coming out of the tank. What did Porsche do about this on their dry-sump systems? I'm running a Hayabusa engine (build thread to follow) so it's a pretty unconventional build but the oiling thing is common to all dry-sumps. Thanks for answering these questions. |
gnomefabtech |
Apr 5 2024, 12:07 PM
I solved it. I am using this valve here:
https://www.mcmaster.com/1874N19/ I added a couple -12AN fittings (you could use barbed if you want that) and plumbed it in between the tank and the engine. Does a good job of preventing the oil from draining down and I see no change in the operating oil pressure. The only down side is that valve is kind of bulky. Not really a problem though. Total cost of $130 shipped. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:52 PM |
