> need shorter oil filter for sandwich, which one to use
RFoulds
post Mar 29 2024, 03:14 PM
914Rennsport
Finally installing my oil lines and the sandwich adaptor is thicker than my old one I think. Using a Derale oil filter adaptor, model no. 15702. this is making my stock Mahle filter OC28 hang down too far and the engine mount bar is in the way.
Has anyone found a shorter filter to use?
RFoulds
post Apr 3 2024, 09:37 AM
914Rennsport
Thanks everyone. Discovered that my issue was that the engine bar is bent at the ends which is causing it lean back about. Half inch. Once I straightened it I had the clearance I needed.
Alapone
post Apr 15 2024, 09:15 AM
QUOTE(RFoulds @ Apr 3 2024, 11:37 AM) *
I am having the same issue with my sandwich plate and Mahle OC28 filter. The correct filter would hit the support bar. I am also having an issue with the clutch cable being in the way while installing. I have used shorter STP filters in the past but am a bit leery of quality and oil capacity. any thoughts ?
5 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
3 Members: gandalf_025, dtmehall, TRP
- Lo-Fi Version Time is now: 9th April 2026 - 07:00 PM
