Cessnaporsche01 |
Member ![]() ![]() Group: Members Posts: 70 Joined: 20-June 23 From: Columbus, Ohio Member No.: 27,426 Region Association: Upper MidWest ![]() |
So a lot of you will remember my thread from last year that ran for many many pages, trying to get my '74 2.0(56) running again after literal years of turmoil and confusion.
After much investigation and many suggestions, I was able to isolate the issue to the MPS, a rebuilt 0280100043 unit, remanufactured by Fuel Injection Corp USA and sold by Rich Bontempi's High Performance House back in 2020. Last fall, I was able to get the car running, idling great and driving spottily by simply using the Tangerine Racing MPS tuning kit to adjust the inner idle screw richer, but was never able to achieve full throttle. I ended up cranking the inner screw up to max, and was able to get about 60% throttle before the engine would die. Although idle became excessively rich, this made the car driveable enough to get it hot. Especially since nearing the cut-out point, it seemed to get very lean. With the warmer weather back, I've been working on trying to tune the car in better, but have been met without much success. But I've dialed in with growing specificity toward what seems to be an MPS transformer problem. I started by doing a full intake system rebuild/re-seal, just to be certain I wasn't fighting a vacuum leak. Slowly and carefully cleaning and re-seating all mating surfaces and using gasket dressing on gaskets. (I also 3D scanned and modeled the intake system, but that's a topic for another thread.) I'm now up to 100% confident that the car has no vacuum leaks, up from maybe 85-90% before. Then I set about adjusting the tuning. I got a proper vacuum pump that could pull up to 25+ inHg and bench tested my MPS. Like last time, the 8-10 coil (secondary) curve came in FAR lower than both the graph value and chart values given on Brad Ander's MPS page, at least on the high-power end of the scale, with the primary coil being around 1/2 the secondary. [Graphs and chart shown below.] With the inner screw maxed out, the 25inHg primary inductance secondary 0.67H and the primary 0.32H. At 0inHg, the secondary approaches .93H and the primary, .49H. Now, I had posted this very low inductance curve in my last thread, and the community consensus was that the shape of the curve was more important than the actual values, but I question this, and wanted to test where the cutout point on my engine's throttle response was, so I hooked a vacuum gauge up to a long hose, plugged it into the manifold port where the decel valve usually goes, and went for a drive. After letting the engine get hot, I did a few pulls, where I gradually increased my throttle position and watched the vacuum. Sure enough, the engine would cut out each time the manifold vacuum fell below about 7-8inHg on the gauge, which is just past the intercept point between my MPS's secondary curve, and the 043 curve Brad has posted on his site. This aligned well enough with my suspicions that I was willing to spend the money to test out another unit. I went out looking, and settled on a 0280100037 unit from EBS Racing, since I couldn't find any verified '043s, and '037s are compatible with my car/ECU - considered to be an "upgrade" due to their higher stock mixture setting. When this one arrived, I found it had also been remanufactured by Fuel Injection Corp. And upon testing its coils, while the curve's shape looked much healthier than my '043's, it was similarly very low. And sure enough, the car wouldn't start on it. What's more, I found that on this unit, the inner adjustment screw was nearly maxed out already, only about a quarter turn from its limit. At this point, I'm scratching my head a bit. Could I really have gotten 2 bad rebuilds in a row? Does the inductance value really not matter, and there's something else wrong with my car? Why are my values both so different than the nominal ones Brad measured? I checked that my LCR meter isn't bad with a 2.2H coil from DigiKey, and it read that more or less dead on. I also pulled the top off my '043 and checked to see that the transformer actuation is free and clear. Even with the core pulled to its limit, the secondary won't go much above 1.0H. The resistances in the coils are correct, so they're not shorted. All I can think is maybe the cores have been replaced with something non-suitable? I know Jeff drove his car with my components last summer, which is further confusing, though I don't know if he tried full throttle or not, and I know my 2056 pulls a little less vacuum than an engine with a stock cam. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-27426-1713200815.1.png) Values: Brad Ander's 043 (based on 2 rebuilt and 1 NOS unit) 0 inHg = 1.39H 4 inHg = 1.18H 15 inHg = 0.71H My Rebuilt 043 0 inHg = 0.929H 4 inHg = 0.915H 15 inHg = 0.809H Brad Ander's 037 (based on 1 rebuilt unit) 0 inHg = 1.44H 4 inHg = 1.26H 15 inHg = 0.72H My Rebuilt 043 0 inHg = 0.943H 4 inHg = 0.883H 15 inHg = 0.601H So I guess, I'd like to ask the forum a favor. Anyone who has an LCR meter and a WORKING D-Jetronic car, if you're willing, do me a favor and check the inductance across your 8-10 coil with no vacuum, and post it here. If you feel like graphing your response curve, all the better! |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,355 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Just my $.02, from my experience: The LCR meter readings are interesting and good guidelines, but to set the MPS correctly, once the outer screw is in the correct ballpark, you really only need to be able to read the AFR for a given vacuum to adjust things further. Even with the exact LCR meter that Anders used, my car wouldn't run correctly when I mirrored his settings. You'll get different readings with different brand LCRs. Yet another reason relying solely on an LCR isn't recommended.
Also, you shouldn't be using the inner screw to dial in WOT. Use the full load stop screw for that. My order of operations: Get the outer screw set first on the bench. I do this by putting the MPS in a vice with the adjustment screws facing up, then insert the adjustment tool in the MPS and rest it upright in place. Then using a vacuum gauge start pulling a vacuum. Adjust the outer screw so you see the tool stop moving down somewhere at around 5-6 in Hg. (reflected in Anders curve you posted above). Then install the MPS in your car and adjust the inner and full load stop screws (in that order) using an AFR wideband sensor to guide adjustments. Just to make sure we're all on the same page regarding which screw is which- I'm using Anders definitions: ![]() |
Cessnaporsche01 |
Just my $.02, from my experience: The LCR meter readings are interesting and good guidelines, but to set the MPS correctly, once the outer screw is in the correct ballpark, you really only need to be able to read the AFR for a given vacuum to adjust things further. Even with the exact LCR meter that Anders used, my car wouldn't run correctly when I mirrored his settings. You'll get different readings with different brand LCRs. Yet another reason relying solely on an LCR isn't recommended. Also, you shouldn't be using the inner screw to dial in WOT. Use the full load stop crew for that. My order of operations: Get the outer screw set first on the bench, then adjust the inner and full load stop screw with the MPS installed in the car using an AFR wideband sensor to guide adjustments. Yeah, what I really should do is take the thing to a dyno to at least get an AFR reading on it. But I'm disinclined to spend a bunch more money without checking off that I'm not overlooking something as simple as a bad unit. You're also correct that the outer screw is the correct adjustment for WOT mixture, but at this point, I'm just running with it uninstalled. I backed it out 'til it was no longer doing anything, and for occasional test runs, it shouldn't hurt the diaphragm to stretch to its limit. The only reason the inner screw is maxed out is that it gives me enough useful throttle range to drive the car for testing. With the idle tuned more correctly that intercept falls well into the teens, and the moment I touch the throttle the car just shuts off. How close were your numbers to Anders'? Were you off by a similar ~30%? I know his guide gives a tolerance of .01H! |
rjames |
Just my $.02, from my experience: The LCR meter readings are interesting and good guidelines, but to set the MPS correctly, once the outer screw is in the correct ballpark, you really only need to be able to read the AFR for a given vacuum to adjust things further. Even with the exact LCR meter that Anders used, my car wouldn't run correctly when I mirrored his settings. You'll get different readings with different brand LCRs. Yet another reason relying solely on an LCR isn't recommended. Also, you shouldn't be using the inner screw to dial in WOT. Use the full load stop crew for that. My order of operations: Get the outer screw set first on the bench, then adjust the inner and full load stop screw with the MPS installed in the car using an AFR wideband sensor to guide adjustments. Yeah, what I really should do is take the thing to a dyno to at least get an AFR reading on it. But I'm disinclined to spend a bunch more money without checking off that I'm not overlooking something as simple as a bad unit. You're also correct that the outer screw is the correct adjustment for WOT mixture, but at this point, I'm just running with it uninstalled. I backed it out 'til it was no longer doing anything, and for occasional test runs, it shouldn't hurt the diaphragm to stretch to its limit. The only reason the inner screw is maxed out is that it gives me enough useful throttle range to drive the car for testing. With the idle tuned more correctly that intercept falls well into the teens, and the moment I touch the throttle the car just shuts off. How close were your numbers to Anders'? Were you off by a similar ~30%? I know his guide gives a tolerance of .01H! I did not say the outer screw is for adjusting WOT. The full load stop screw is for that. Running the car without the full load stop screw will shorten the life of the diaphragm. Not a good idea and not necessary if you use the replacement full load stop screw that's provided with the kit since you can adjust the inner screw and outer screws with the full load stop crew in place. You can't adjust the MPS correctly without a wideband AFR sensor. Forget the LCR numbers. You're chasing your tail with those at this point. That said, a number of people, including myself, posted their numbers on an earlier thread. (The #s I posted in the thread aren't current anymore as I've made some adjustments since then). MPS Tuning Analysis Thread ![]() |
Lo-Fi Version | Time is now: 3rd September 2025 - 07:52 PM |
