914-6 Oil Cooler Differences |
DennisV |
Aug 14 2022, 10:15 AM
Member Group: Members Posts: 479 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Can anyone tell me what difference is between the two oiler coolers that are listed in the parts catalog for 914-6? My experience has been when multiple parts are listed, one superseded the other and are the same form, fit, function. What is throwing me off is quite a wide difference in price on these. Roughly $500 delta for the places that offer both (e.g. Pelican, Porsche Atlanta Perimeter, Auto Atlanta, etc.)
Thanks. |
pencap914 |
Apr 10 2024, 09:19 AM
Member Group: Members Posts: 75 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
Just to be clear; the "911 style" oil cooler with the straight push-on fitting will not clear the suspension in a 914? (Picture below)
If that's the case, is it possible to have a skilled welder (*cough* @MB911 ) modify the stock 911 oil cooler to fit a 914? Or should I start shopping for a replacement cooler? The CFS #8260 looks like its made for a 914/6 conversion: https://y7y6i2a9.rocketcdn.me/wp-content/up...-8260-Flyer.pdf |
IronHillRestorations |
Apr 15 2024, 01:29 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Just to be clear; the "911 style" oil cooler with the straight push-on fitting will not clear the suspension in a 914? (Picture below) If that's the case, is it possible to have a skilled welder (*cough* @MB911 ) modify the stock 911 oil cooler to fit a 914? Or should I start shopping for a replacement cooler? The CFS #8260 looks like its made for a 914/6 conversion: https://y7y6i2a9.rocketcdn.me/wp-content/up...-8260-Flyer.pdf I have modified the later style 911 oil cooler with an aluminum 90* fitting that is-12AN and 3/4 NPT. You cut off the tube flush with the end of the cooler and tap it with a 3/4 NPT tap. The tricky part is you want to have it thread in all the way and point forward and about 4* down. Then you are good to go with-12 hoses and fittings. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:48 AM |
