> Aftermarket 2.0L injectors and rails?
JeffBowlsby
post Jul 15 2023, 05:18 PM
Anyone used these? I thought there was a thread on them a couple years ago but could not locate it.
https://injector-rehab.com/product/complete...ctors-included/
JeffBowlsby
post Apr 20 2024, 08:42 AM
Nice to see this installed, thanks for posting. Can you elaborate?
Do the fuel rails or AN fittings touch the engine tin?
How rigid is this assembly? Its cantilevered, what are the possibilities that it will deflect enough to cause the injector bodies to become dislodged?
Are these post engine install only? It appears that the fuel rails would conflict with the engine shelf on each side if the engine were dropped.
Do the fuel injector branches on the harness really need to be extended? From the photos, there appears to be plenty of harness left if the harness connections are correctly rotated. Be sure to cover any exposed wires 100% in heat shrink. Engine heat will be the death of the exposed wires in short order. Also concerned about the same condition in your existing harness by cyl #3 in the second photo, and hope those wires are not already baked.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:38 PM
