Is the Backpad vinyl glued down |
seanpaulmc |
Apr 19 2024, 03:08 PM
Member Group: Members Posts: 304 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Does the vinyl of the Backpad get glued (contact cement) to the backer board? The portion hidden behind the seat.
Mine is detached and floating off the backer board but is retained on the sides. Thanks, Sean |
mepstein |
Apr 20 2024, 11:55 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Weldwood contact cement. Available almost everywhere. Two light coats on each surface. Use a cheap foam brush. Let it dry at least 2x what it says in the directions. Press together and you’re done.
*contact cement must be completely dry before you press surfaces together. Better to wait an hour longer than you think than to do it 5 minutes too little. Wet contact cement re-activates dry contact cement so let everything dry thoroughly. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:24 PM |
