turned my distributor by accident...how to tell where to turn it back ?, My distributor is loose...how can I tell where to tighten it without a timing light? |
second wind |
Apr 23 2024, 01:14 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello out there....due to rain and such have not driven my '73 2.0 very much lately so when my truck needed to go to the mechanic I drove my 914 around for a day or so.....I noticed it had a weird idle so I thought must be a vacuum leak.....sure enough I found the vacuum hose to the distributor had fallen off....when I went to put it back on the distributor twisted and I see it can be turned a inch in either direction....how can I determine where to tighten it without a timing light? Can I listen for a sweet spot and call it good? Do tell..?? Thank you very much!
gg |
technicalninja |
Apr 23 2024, 02:01 PM
Senior Member Group: Members Posts: 1,342 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Jacks RIGHT! (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Just did another search. This is the light to get as it also has a dwell meter. The dwell meter is basically useless unless you have old school points and condenser at which point it's PRICELESS! https://www.amazon.com/dp/B000EVU8J8?ref=em..._i_atc&th=1 If you're still running the stock distributor that is the light to get! It will work fine with modern stuff too. (80-some early 2000s). Nothing works with "coil on plug" but you don't set timing on those anyway. Most modern engines have lost the timing marks as well! |
Lo-Fi Version | Time is now: 10th June 2024 - 12:36 AM |
