Fresh Air Box Vent Block Off, Want to permanently remove air box |
Nor.Cal.914 |
Apr 26 2024, 09:53 AM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
As the title states, I'm in the process of deleting all of my HVAC components and the last thing I have left is the removal of the fresh air box/blower motor housing. I have found the block off plates needed for the 6 vent and hose holes, but I'm having trouble finding someone who makes something to seal off the fresh air vent for the air box. I tried searching here, went through about 10 pages with no luck of finding anything other than how to remove and rebuild the box.
Does anyone know of someone who makes a block off plate for the vent on the cowl? I guess worst case scenario would be to just make something from sheet metal, but would be nice if there is a kit already made with the seal, hardware, etc. Thank you! |
mlindner |
Apr 27 2024, 05:10 AM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I have mine closed off. Bent sheet metal, some 1/4 inch foam tape to seal and a drain hole with tubing to the underside. Not sure why I did this, car is not driven in the rain. Best, Mark
Lo-Fi Version | Time is now: 2nd June 2024 - 01:10 PM |
