No start 1974 2.0, 1974 2.0 will not start after 2 hour drive |
zaballosc |
Apr 27 2024, 12:59 PM
Newbie Group: Members Posts: 19 Joined: 31-August 15 From: Whitewater, WI Member No.: 19,118 Region Association: Upper MidWest |
Hi all,
We just drove our 914 to Road America after 2 years of incremental work. Over the past year it has started perfectly, and it did the drive perfectly. It has a new starter that has been working great. We parked for registration, and when we got back to the car it would not crank. Fuel pump is running, electrical is working, but the car is not cranking or starting on a bump start. Any ideas? I checked the relays and relay board connections. Currently waiting on a tow. |
zaballosc |
Apr 27 2024, 05:55 PM
Hi all, thank you for all of the advice.
I was able to get it towed home, to answer one of your questions it is a FI car. We got it back home on a lift and found that 12.9 volts of power is reaching the starter. So I am thinking that we might have a bad starter. Drats! it was so easy to install when the motor was on the ground, now i'm considering what the swap will be like while it's in the car. |
bkrantz |
Apr 27 2024, 07:58 PM
914 Guru Group: Members Posts: 7,811 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Hi all, thank you for all of the advice. I was able to get it towed home, to answer one of your questions it is a FI car. We got it back home on a lift and found that 12.9 volts of power is reaching the starter. So I am thinking that we might have a bad starter. Drats! it was so easy to install when the motor was on the ground, now i'm considering what the swap will be like while it's in the car. Not a bad job if you can lift the car high enough to work comfortably and SAFELY underneath. |
Lo-Fi Version | Time is now: 16th June 2024 - 06:05 AM |
