| 930cabman |
May 8 2024, 05:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,873 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
My /6 conversion is going on 3 years as it seems as many do. I had a local old school reputable shop build the stock 2.7, case was done at Ollies, .... should be a great engine. Finally trying to get her barking, but just won't take hold. While cranking she wants to start, but when I release the starter, she conks out. We have a spark (not real significant), timing is close, carbs appear ok.
Is it possible the valves or maybe rings are not sealing because the engine sat for about 2 years? |
| Root_Werks |
May 9 2024, 10:00 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,078 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Would certainly do a simple compression test, just to make sure those numbers are good enough to start the engine.
Would agree with most, probably something simple, timing too far or ignition switch cutting power after you let off the start position. Would really hope the cams are not 180 out. (IMG:style_emoticons/default/sad.gif) |
| 930cabman |
May 9 2024, 01:14 PM
Would certainly do a simple compression test, just to make sure those numbers are good enough to start the engine. Would agree with most, probably something simple, timing too far or ignition switch cutting power after you let off the start position. Would really hope the cams are not 180 out. (IMG:style_emoticons/default/sad.gif) My engine builder has probably built hundreds of 911 engines, I suspect the fault does not lie with the engine internals. dumb question: how/why would the power to the coil not be energized after releasing the ignition switch? Prior to the /6 conversion, she was a running /4. Nothing was changed in the main wiring harness |
| Root_Werks |
May 9 2024, 03:44 PM
Would certainly do a simple compression test, just to make sure those numbers are good enough to start the engine. Would agree with most, probably something simple, timing too far or ignition switch cutting power after you let off the start position. Would really hope the cams are not 180 out. (IMG:style_emoticons/default/sad.gif) My engine builder has probably built hundreds of 911 engines, I suspect the fault does not lie with the engine internals. dumb question: how/why would the power to the coil not be energized after releasing the ignition switch? Prior to the /6 conversion, she was a running /4. Nothing was changed in the main wiring harness Could be a bad ignition switch, it happens. Easy to test. Just ensure the terminal that powers the coil/CDI stays alive in Run and Start positions. Fingers crossed it's still something simple. Others have already said, if compression comes back really low, likely not a good sign. Could try to squirt some LR2 (for you aviation folks) down each plug hole and try again. If numbers are still really low, likely cam timing or very ill adjusted valve lash. |
| flyer86d |
May 10 2024, 05:42 AM
Member ![]() ![]() Group: Members Posts: 488 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Would certainly do a simple compression test, just to make sure those numbers are good enough to start the engine. Would agree with most, probably something simple, timing too far or ignition switch cutting power after you let off the start position. Would really hope the cams are not 180 out. (IMG:style_emoticons/default/sad.gif) My engine builder has probably built hundreds of 911 engines, I suspect the fault does not lie with the engine internals. dumb question: how/why would the power to the coil not be energized after releasing the ignition switch? Prior to the /6 conversion, she was a running /4. Nothing was changed in the main wiring harness Could be a bad ignition switch, it happens. Easy to test. Just ensure the terminal that powers the coil/CDI stays alive in Run and Start positions. Fingers crossed it's still something simple. Others have already said, if compression comes back really low, likely not a good sign. Could try to squirt some LR2 (for you aviation folks) down each plug hole and try again. If numbers are still really low, likely cam timing or very ill adjusted valve lash. I’ve seen ignition switches fail as you described. It will try to run while cranking the starter and quit as soon as the key is released. Charlie |
930cabman Fresh 2.7 May 8 2024, 05:23 PM
Superhawk996 Fuel
Compression
Spark
Something is missing or... May 8 2024, 05:29 PM
930cabman
Fuel
Compression
Spark
Something is missing o... May 9 2024, 06:01 AM
technicalninja Run a compression test. If low add 1/2 oz of ATF/W... May 8 2024, 05:36 PM
mepstein Don’t panic, it’s usually something simple.
... May 8 2024, 05:46 PM
nditiz1 Can you confirm fuel is getting down the throats w... May 8 2024, 06:49 PM
930cabman
Can you confirm fuel is getting down the throats ... May 9 2024, 05:47 AM
Luke M
[quote name='nditiz1' post='3144117' date='May 8 ... May 9 2024, 05:54 AM
930cabman
[quote name='930cabman' post='3144161' date='May ... May 9 2024, 06:05 AM
flyer86d I had the same issue with the 2.7 that I put toget... May 9 2024, 05:05 AM
930cabman
I had the same issue with the 2.7 that I put toge... May 9 2024, 05:56 AM
flyer86d
I had the same issue with the 2.7 that I put tog... May 9 2024, 02:52 PM
930cabman
[quote name='930cabman' post='3144165' date='May ... May 9 2024, 03:40 PM
mb911 Ok so I will echo wrong cam timing. A friend bough... May 9 2024, 06:04 AM
Retroracer @930cabman - hope recovery from the health issues... May 9 2024, 08:26 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 9 2024, 09:37 AM
gereed75 Incorrect fuel level in carbs can result in a no g... May 9 2024, 08:31 AM
930cabman
Incorrect fuel level in carbs can result in a no ... May 9 2024, 09:40 AM
Superhawk996
Would really hope the cams are not 180 out. :(
... May 9 2024, 01:06 PM
mb911
Would certainly do a simple compression test, ju... May 9 2024, 01:17 PM
technicalninja Running the compression test WILL verify cam timin... May 9 2024, 01:45 PM
930cabman
Running the compression test WILL verify cam timi... May 9 2024, 03:37 PM
gereed75 I had the exact same symptoms.
Changed the igniti... May 10 2024, 08:20 AM
930cabman
Changed the ignit... May 10 2024, 08:59 AM
930cabman Checked power at the coil + terminal, solid 12volt... May 23 2024, 12:28 PM
Root_Werks
Checked power at the coil + terminal, solid 12vol... May 23 2024, 12:41 PM
930cabman I have noticed a rather large (more than I am used... May 23 2024, 03:36 PM
Geezer914 Any possibility of a vacuum leak? May 23 2024, 03:44 PM
930cabman
Thanks, but i... May 25 2024, 01:26 PM
Superhawk996
Thanks, but ... May 25 2024, 01:51 PM
930cabman
[quote name='930cabman' post='3147314' date='May ... May 25 2024, 04:38 PM
IronHillRestorations I’m going to guess the distributor timing is inc... May 25 2024, 06:45 PM
thomasotten Distributor firing order. May 25 2024, 07:10 PM
930cabman Checking ohms across the + battery cable (when dis... May 26 2024, 07:27 AM
Superhawk996
Checking ohms across the + battery cable (when di... May 26 2024, 07:48 AM
930cabman
Checking ohms across the + battery cable (when d... May 26 2024, 08:09 AM
mlindner I moved the battery to the trunk. Then fabricated ... May 26 2024, 08:27 AM
930cabman
I moved the battery to the trunk. Then fabricated... May 26 2024, 10:17 AM
Superhawk996 Got it.
Agree the 170 ohms on the /6 is not ide... May 26 2024, 10:20 AM
930cabman
Got it.
Agree the 170 ohms on the /6 is not id... May 26 2024, 04:44 PM
mb911
Got it.
Agree the 170 ohms on the /6 is not i... May 26 2024, 05:05 PM
windforfun "Ohms law: 12v / 170 ohms = .071 amps of para... May 26 2024, 05:47 PM
Superhawk996
Hmmm... 71 mA is enough to kill you. IMHO, thi... May 26 2024, 08:43 PM
930cabman I sense the compression is good based on the sound... May 26 2024, 06:02 PM
mb911
I sense the compression is good based on the soun... May 26 2024, 07:36 PM
Superhawk996
I sense the compression is good based on the sou... May 26 2024, 08:23 PM
technicalninja windforfun, thought you are an EE Sir!
It... May 26 2024, 06:04 PM
930cabman
It... May 26 2024, 06:21 PM
windforfun
It... May 26 2024, 07:19 PM
technicalninja I'll put the draw issue to bed with this...
A... May 26 2024, 07:15 PM
Superhawk996
The draw is a "red herring" in the tro... May 26 2024, 08:49 PM
technicalninja Just remembered a stock 914 parasitic draw...
Only... May 26 2024, 09:14 PM
Superhawk996
Onl... May 26 2024, 09:21 PM
930cabman ON TO SOMETHING
as you can imagine, this driving ... May 27 2024, 06:02 AM
930cabman She lives :Qarl:
Spark timing was retarded by ... May 29 2024, 02:54 PM
mate914
She lives :Qarl:
Spark timing was retarded by... May 29 2024, 07:27 PM
930cabman
She lives :Qarl:
Spark timing was retarded b... May 30 2024, 04:55 AM
930cabman
She lives :Qarl:
Spark timing was retarded b... Jul 7 2024, 08:37 AM
mate914
[quote name='mate914' post='3148162' date='May 29... Jul 7 2024, 09:00 AM
Root_Werks Very glad this had a happy ending! Or rather ... May 30 2024, 09:29 AM
930cabman Thank you to all contributors, she is running dece... May 30 2024, 03:14 PM
flyer86d As I found out on my 2.7, set up the Webers on ini... May 30 2024, 03:32 PM
930cabman
As I found out on my 2.7, set up the Webers on in... May 31 2024, 08:08 AM
IronHillRestorations @930cabman check your oil lines. Sounds like you ... Jul 7 2024, 09:08 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 7 2024, 11:58 AM
mate914
[b]@[url=http://www.914world.com/bbs2/index.php?... Jul 7 2024, 12:22 PM
sixnotfour the bypass for the oil filter is in the console ,,... Jul 7 2024, 09:13 AM
sixnotfour top right, Jul 7 2024, 09:23 AM
mb911 What console do you have? I have seen reports on t... Jul 7 2024, 09:46 AM
930cabman
What console do you have? I have seen reports on ... Jul 7 2024, 11:57 AM
930cabman What appears to be some sort of pressure valve ins... Jul 7 2024, 02:35 PM
mb911
What appears to be some sort of pressure valve in... Jul 7 2024, 02:47 PM
930cabman Been wrenching for 50+ years, never seen an oil fi... Jul 7 2024, 03:20 PM
sixnotfour is this an oc 54..not the early filter. Jul 7 2024, 03:51 PM
930cabman
If memo... Jul 7 2024, 03:56 PM
sixnotfour
If mem... Jul 7 2024, 04:00 PM
rudedude Other 911 owners have had issues with oil filters ... Jul 8 2024, 11:00 AM
mb911
Other 911 owners have had issues with oil filters... Jul 8 2024, 12:02 PM
930cabman
[quote name='rudedude' post='3155381' date='Jul 8... Jul 8 2024, 01:35 PM
mb911
[quote name='mb911' post='3155387' date='Jul 8 20... Jul 8 2024, 01:46 PM
technicalninja Seeing no oil at all in the filter would bug the c... Jul 8 2024, 02:10 PM
930cabman
Seeing no oil at all in the filter would bug the ... Jul 8 2024, 03:10 PM
mb911 http://forums.pelicanparts.com/porsche-911...oil-f... Jul 8 2024, 02:23 PM
930cabman
http://forums.pelicanparts.com/porsche-911...oil-... Jul 8 2024, 03:19 PM
930cabman https://mahle.integrityplatform.org/
Wonder if th... Jul 8 2024, 03:24 PM
mate914
Wonder if t... Jul 8 2024, 06:24 PM
930cabman
[quote name='930cabman' post='3155427' date='Jul ... Jul 8 2024, 07:00 PM
930cabman No good
Appears some sort of valve has found i... Jul 9 2024, 01:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 08:58 AM |
