> 4-Pole door contact switch, Does anyone sell them? Is there a work-around?
gord
post May 23 2024, 01:13 PM
I bought two different kinds of door contact switches, based on what is listed in the PET catalogue. Then when I pulled the broken switch out of my door jamb, it was of the 4-pole variety, which is not listed in the PET at all.
I have not been able to find this part anywhere online, not even a proper part number other than the "8842 K" that is molded into the plastic.
Does anyone sell these?
Or is there a good way of wiring a replacement switch that preserves the buzzer circuit? Or will I just have to disconnect that and wire with the later year 2-pole + ground switch?
This is the relevant section of the wiring diagram (1972), in case anyone is wondering:
Any help would be much appreciated!
FlacaProductions
post May 23 2024, 02:47 PM
Something like this piggyback work to convert without changing the wiring?
(or are the switch connectors the smaller variety - i can't remember)
https://www.digikey.com/en/products/detail/...EcaAtbEEALw_wcB
gord
post May 23 2024, 04:42 PM
QUOTE(FlacaProductions @ May 23 2024, 02:47 PM) *
Unfortunately it's not that simple. The original switch is DPST and closes two separate circuits: (1) it grounds the cabin light, and (2) it completes the circuit from the key-in ignition switch to the buzzer and seatbelt light... if you just piggyback the buzzer circuit on the cabin light circuit, the buzzer will sound every time the door is open, even without a key in the ignition... (IMG:style_emoticons/default/headbang.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 12:15 PM
