> Fresh 2.7, doesn't want to wake up
930cabman
post May 8 2024, 05:23 PM
My /6 conversion is going on 3 years as it seems as many do. I had a local old school reputable shop build the stock 2.7, case was done at Ollies, .... should be a great engine. Finally trying to get her barking, but just won't take hold. While cranking she wants to start, but when I release the starter, she conks out. We have a spark (not real significant), timing is close, carbs appear ok.
Is it possible the valves or maybe rings are not sealing because the engine sat for about 2 years?
930cabman
post May 26 2024, 07:27 AM
Checking ohms across the + battery cable (when disconnected) and the negative cable should be 0 ohms. Correct or incorrect?
This is confirmed with my well running 2056, 0 ohms
Moving to my /6 conversion, not so. Checking across the + battery cable (when disconnected) and the negative battery I am getting 170 ohms
Checking across one pair of red cables ( normally connected to the + battery cable) and the negative cable I am getting a reading of approx 400 ohms, but quickly goes to much higher reading.
Checking across the MSD heavy red cable and the battery negative cable I am reading 12K ohms
Currently putting a full charge in the battery, will try for actual voltage when cranking. I suspect there is a short or more somewhere.
930cabman   Fresh 2.7   May 8 2024, 05:23 PM
Superhawk996   Fuel Compression Spark Something is missing or...   May 8 2024, 05:29 PM
930cabman   Fuel Compression Spark Something is missing o...   May 9 2024, 06:01 AM
technicalninja   Run a compression test. If low add 1/2 oz of ATF/W...   May 8 2024, 05:36 PM
mepstein   Don’t panic, it’s usually something simple. ...   May 8 2024, 05:46 PM
nditiz1   Can you confirm fuel is getting down the throats w...   May 8 2024, 06:49 PM
930cabman   Can you confirm fuel is getting down the throats ...   May 9 2024, 05:47 AM
Luke M   [quote name='nditiz1' post='3144117' date='May 8 ...   May 9 2024, 05:54 AM
930cabman   [quote name='930cabman' post='3144161' date='May ...   May 9 2024, 06:05 AM
flyer86d   I had the same issue with the 2.7 that I put toget...   May 9 2024, 05:05 AM
930cabman   I had the same issue with the 2.7 that I put toge...   May 9 2024, 05:56 AM
flyer86d   I had the same issue with the 2.7 that I put tog...   May 9 2024, 02:52 PM
930cabman   [quote name='930cabman' post='3144165' date='May ...   May 9 2024, 03:40 PM
mb911   Ok so I will echo wrong cam timing. A friend bough...   May 9 2024, 06:04 AM
Retroracer   @930cabman - hope recovery from the health issues...   May 9 2024, 08:26 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 9 2024, 09:37 AM
gereed75   Incorrect fuel level in carbs can result in a no g...   May 9 2024, 08:31 AM
930cabman   Incorrect fuel level in carbs can result in a no ...   May 9 2024, 09:40 AM
Root_Werks   Would certainly do a simple compression test, just...   May 9 2024, 10:00 AM
Superhawk996   Would really hope the cams are not 180 out. :( ...   May 9 2024, 01:06 PM
930cabman   Would certainly do a simple compression test, jus...   May 9 2024, 01:14 PM
mb911   Would certainly do a simple compression test, ju...   May 9 2024, 01:17 PM
Root_Werks   Would certainly do a simple compression test, ju...   May 9 2024, 03:44 PM
flyer86d   [quote name='930cabman' post='3144246' date='May ...   May 10 2024, 05:42 AM
technicalninja   Running the compression test WILL verify cam timin...   May 9 2024, 01:45 PM
930cabman   Running the compression test WILL verify cam timi...   May 9 2024, 03:37 PM
gereed75   I had the exact same symptoms. Changed the igniti...   May 10 2024, 08:20 AM
930cabman   I had the exact same symptoms. Changed the ignit...   May 10 2024, 08:59 AM
930cabman   Checked power at the coil + terminal, solid 12volt...   May 23 2024, 12:28 PM
Root_Werks   Checked power at the coil + terminal, solid 12vol...   May 23 2024, 12:41 PM
930cabman   I have noticed a rather large (more than I am used...   May 23 2024, 03:36 PM
Geezer914   Any possibility of a vacuum leak?   May 23 2024, 03:44 PM
930cabman   Any possibility of a vacuum leak? Thanks, but i...   May 25 2024, 01:26 PM
Superhawk996   Any possibility of a vacuum leak? Thanks, but ...   May 25 2024, 01:51 PM
930cabman   [quote name='930cabman' post='3147314' date='May ...   May 25 2024, 04:38 PM
IronHillRestorations   I’m going to guess the distributor timing is inc...   May 25 2024, 06:45 PM
thomasotten   Distributor firing order.   May 25 2024, 07:10 PM
930cabman   Checking ohms across the + battery cable (when dis...   May 26 2024, 07:27 AM
Superhawk996   Checking ohms across the + battery cable (when di...   May 26 2024, 07:48 AM
930cabman   Checking ohms across the + battery cable (when d...   May 26 2024, 08:09 AM
mlindner   I moved the battery to the trunk. Then fabricated ...   May 26 2024, 08:27 AM
930cabman   I moved the battery to the trunk. Then fabricated...   May 26 2024, 10:17 AM
Superhawk996   Got it. Agree the 170 ohms on the /6 is not ide...   May 26 2024, 10:20 AM
930cabman   Got it. Agree the 170 ohms on the /6 is not id...   May 26 2024, 04:44 PM
mb911   Got it. Agree the 170 ohms on the /6 is not i...   May 26 2024, 05:05 PM
windforfun   "Ohms law: 12v / 170 ohms = .071 amps of para...   May 26 2024, 05:47 PM
Superhawk996   Hmmm... 71 mA is enough to kill you. IMHO, thi...   May 26 2024, 08:43 PM
930cabman   I sense the compression is good based on the sound...   May 26 2024, 06:02 PM
mb911   I sense the compression is good based on the soun...   May 26 2024, 07:36 PM
Superhawk996   I sense the compression is good based on the sou...   May 26 2024, 08:23 PM
technicalninja   windforfun, thought you are an EE Sir! It...   May 26 2024, 06:04 PM
930cabman   windforfun, thought you are an EE Sir! It...   May 26 2024, 06:21 PM
windforfun   windforfun, thought you are an EE Sir! It...   May 26 2024, 07:19 PM
technicalninja   I'll put the draw issue to bed with this... A...   May 26 2024, 07:15 PM
Superhawk996   The draw is a "red herring" in the tro...   May 26 2024, 08:49 PM
technicalninja   Just remembered a stock 914 parasitic draw... Only...   May 26 2024, 09:14 PM
Superhawk996   Just remembered a stock 914 parasitic draw... Onl...   May 26 2024, 09:21 PM
930cabman   ON TO SOMETHING as you can imagine, this driving ...   May 27 2024, 06:02 AM
930cabman   She lives :Qarl: Spark timing was retarded by ...   May 29 2024, 02:54 PM
mate914   She lives :Qarl: Spark timing was retarded by...   May 29 2024, 07:27 PM
930cabman   She lives :Qarl: Spark timing was retarded b...   May 30 2024, 04:55 AM
930cabman   She lives :Qarl: Spark timing was retarded b...   Jul 7 2024, 08:37 AM
mate914   [quote name='mate914' post='3148162' date='May 29...   Jul 7 2024, 09:00 AM
Root_Werks   Very glad this had a happy ending! Or rather ...   May 30 2024, 09:29 AM
930cabman   Thank you to all contributors, she is running dece...   May 30 2024, 03:14 PM
flyer86d   As I found out on my 2.7, set up the Webers on ini...   May 30 2024, 03:32 PM
930cabman   As I found out on my 2.7, set up the Webers on in...   May 31 2024, 08:08 AM
IronHillRestorations   @930cabman check your oil lines. Sounds like you ...   Jul 7 2024, 09:08 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 7 2024, 11:58 AM
mate914   [b]@[url=http://www.914world.com/bbs2/index.php?...   Jul 7 2024, 12:22 PM
sixnotfour   the bypass for the oil filter is in the console ,,...   Jul 7 2024, 09:13 AM
sixnotfour   top right,   Jul 7 2024, 09:23 AM
mb911   What console do you have? I have seen reports on t...   Jul 7 2024, 09:46 AM
930cabman   What console do you have? I have seen reports on ...   Jul 7 2024, 11:57 AM
930cabman   What appears to be some sort of pressure valve ins...   Jul 7 2024, 02:35 PM
mb911   What appears to be some sort of pressure valve in...   Jul 7 2024, 02:47 PM
930cabman   Been wrenching for 50+ years, never seen an oil fi...   Jul 7 2024, 03:20 PM
sixnotfour   is this an oc 54..not the early filter.   Jul 7 2024, 03:51 PM
930cabman   is this an oc 54..not the early filter. If memo...   Jul 7 2024, 03:56 PM
sixnotfour   is this an oc 54..not the early filter. If mem...   Jul 7 2024, 04:00 PM
rudedude   Other 911 owners have had issues with oil filters ...   Jul 8 2024, 11:00 AM
mb911   Other 911 owners have had issues with oil filters...   Jul 8 2024, 12:02 PM
930cabman   [quote name='rudedude' post='3155381' date='Jul 8...   Jul 8 2024, 01:35 PM
mb911   [quote name='mb911' post='3155387' date='Jul 8 20...   Jul 8 2024, 01:46 PM
technicalninja   Seeing no oil at all in the filter would bug the c...   Jul 8 2024, 02:10 PM
930cabman   Seeing no oil at all in the filter would bug the ...   Jul 8 2024, 03:10 PM
mb911   http://forums.pelicanparts.com/porsche-911...oil-f...   Jul 8 2024, 02:23 PM
930cabman   http://forums.pelicanparts.com/porsche-911...oil-...   Jul 8 2024, 03:19 PM
930cabman   https://mahle.integrityplatform.org/ Wonder if th...   Jul 8 2024, 03:24 PM
mate914   https://mahle.integrityplatform.org/ Wonder if t...   Jul 8 2024, 06:24 PM
930cabman   [quote name='930cabman' post='3155427' date='Jul ...   Jul 8 2024, 07:00 PM
930cabman   No good Appears some sort of valve has found i...   Jul 9 2024, 01:40 PM
- Lo-Fi Version Time is now: 31st October 2026 - 09:00 AM
