> 4-Pole door contact switch, Does anyone sell them? Is there a work-around?
gord
post May 23 2024, 01:13 PM
I bought two different kinds of door contact switches, based on what is listed in the PET catalogue. Then when I pulled the broken switch out of my door jamb, it was of the 4-pole variety, which is not listed in the PET at all.
I have not been able to find this part anywhere online, not even a proper part number other than the "8842 K" that is molded into the plastic.
Does anyone sell these?
Or is there a good way of wiring a replacement switch that preserves the buzzer circuit? Or will I just have to disconnect that and wire with the later year 2-pole + ground switch?
This is the relevant section of the wiring diagram (1972), in case anyone is wondering:
Any help would be much appreciated!
914Sixer
post May 23 2024, 02:33 PM
Put a WTB in classified section. NLA everywhere. Never did find a VW cross reference for these.
gord
post May 23 2024, 04:45 PM
QUOTE(914Sixer @ May 23 2024, 02:33 PM) *
Thanks. I found a pair on ebay. The lack of a part reference is really strange - it's clearly stamped as VW part, but I can't find it described anywhere and there seems to be no Porsche part number attached to it either, or it would be correctly listed in the PET.
JamesM
post May 25 2024, 04:50 PM
QUOTE(gord @ May 23 2024, 02:45 PM) *
113 947 561 E
Not easy to find as most parts houses have that part number shown with the 2 pole version but...
Here you go
https://www.volkswagen-classic-parts.com/ca...11-412&ct=2
If you have used ones though they are pretty easy to dissemble and not a complicated part or prone to breaking other than the internal spring rusting out.
gord
post May 27 2024, 08:12 AM
QUOTE(JamesM @ May 25 2024, 04:50 PM) *
So the used one I picked up is partially faulty (only one pair of the contacts will close, probably due to rust). What's the best way to disassemble these without destroying the plastic housing? @JamesM
JamesM
post May 27 2024, 10:26 PM
QUOTE(gord @ May 27 2024, 06:12 AM) *
The plunger/button just screws off and allows the sliding part of the switch to come out the bottom. surprisingly simple part once you break it down.
- Lo-Fi Version Time is now: 2nd April 2026 - 12:16 PM
