| sjhenry1075 |
Jun 3 2024, 12:24 PM
Member ![]() ![]() Group: Members Posts: 270 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States
I hate to even post this, but I'm going to ask a bunch of few dumb questions so please bare with me. My car was painted two years ago and in my haste to drop the engine (1.7 with Djet) I did not take a lot of pictures of the wiring harnesses nor did I mark the wires. No, it they not have to be removed, but I did remove them. Yes, Huge mistake. Worst part is, the PO messed with the harness so none of the wire colors are correct.
As you probably guessed, I'm left with kind of a mess. I printed out Bowlsby's diagrams for the harnesses and the 12 point plug (which came apart during the removal process) and tested all the connections for continuity and started to put it back on the car. I few things are stumping me right now and here are my questions: - My fuel pump no longer comes on. I looked at the wiring schematic and it shows a fuel pump wire going to the 12 pin harness, pin 12 from pin 13 of the 14 pin harness. That wire is supposed to go to the AAR valve correct? - Is there a wire that goes from the starter to the little box in the engine compartment? It's attached to the side of the trunk and has three posts. On my Mustang it was considered the selonoid, but I'm not sure it's the same on the 914. Do my questions make sense? I have never been good at electrical stuff. I definitely appreciate any assistance and if you want to call me a dummy that's fine too.. - |
| windforfun |
Jun 4 2024, 12:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
CTTOI, the fuel pump wiring should have a rather unique connector on it with perhaps a rubber boot too. Simple spade lugs are not stock. Don't reverse the polarity because this will make the pump run backwards.
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
sjhenry1075 Electrical Jun 3 2024, 12:24 PM
windforfun Okay, so let's step back & think about thi... Jun 3 2024, 07:48 PM
Superhawk996 You are facing a bit of an uphill battle especiall... Jun 3 2024, 11:01 PM
Superhawk996 :ttiwwp:
I’m sort of guessing what you’re ask... Jun 3 2024, 11:16 PM
930cabman The drawing from Superhawk is a great starting poi... Jun 4 2024, 02:07 PM
ClayPerrine
The drawing from Superhawk is a great starting po... Jun 4 2024, 02:35 PM
Superhawk996 :agree: Clay :worship: - not me. I just recycle ... Jun 4 2024, 03:51 PM
sjhenry1075 Thank you for the advice everyone, hopefully I... Jun 5 2024, 09:17 AM
Superhawk996
Thank you for the advice everyone, hopefully I... Jun 5 2024, 10:09 AM
dr914@autoatlanta.com Maybe watching this old guy will help:
https://w... Jun 5 2024, 09:49 AM
windforfun
https://... Jun 5 2024, 10:14 AM
windforfun George got me curious so I uncovered my relay boar... Jun 5 2024, 02:30 PM
Superhawk996
Is this factory stock? TIA.
Not stock.
The ... Jun 5 2024, 11:34 PM
sjhenry1075 I want to thank everyone for their replies and ass... Jun 14 2024, 08:24 AM
930cabman Don't think you are alone, more than one of us... Jun 14 2024, 12:42 PM
windforfun Well at least you didn't short out your batter... Jun 14 2024, 02:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th August 2026 - 07:24 PM |
