fiacra |
Person.Woman.Man.Camera.TV ![]() ![]() ![]() Group: Members Posts: 580 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California ![]() ![]() |
Taking a break today to allow my hands to recover and my wounds to heal, so I thought I'd share the experiences of the past few weeks. I'm sure this story is going to sound mighty familiar to many of you. Sharing it for your amusement, and because that's what we do on this forum.
This all started with a bit of a front end wobble when applying the brakes. No big deal, just a warped rotor. A quick check of the braking system then revealed a leaking MC. Not the most pleasant job in the world, as many of you will know, but you can't safely drive a car with a failing MC so I did what was necessary, but man was it painful. Bleeding these systems can also be challenging, but three quarts of brake fluid later I was satisfied that there was no more air in the system and I had proudly achieved a very firm pedal. I absolutely love my Motiv pressure bleeder. It took a while to get back to the rotors, but after some limited driving I put the car up on the scissor lift and decided that while it was up there would be a good time to also change the engine oil and the transaxle oil. While changing the transaxle oil I suddenly remembered that 914Rubber speedo drive gear guide bushing kit that I bought a while back and thought this would be the perfect time to put it in. Mind you, my current drive gear guide bushing was not leaking so I'm now fixing a problem that I don't actually have. Old guide out, new guide in, super easy. Right? Well, to a certain extent. When reinstalling the guide retaining bolt the threaded insert (yes, the factory uses a heli-coil here) failed and I was faced with a stripped bolt hole. A few days of research, a new thread (no pun intended, and with thanks to everyone for their advice), and I learned all I wanted to know about heli-coils, time-serts, and big-serts, none of which I had ever used before. Well, one expensive time-sert kit that I hopefully will never use again and that issue was solved. The transaxle refilled, I moved up to the front again to do the rotors and bearings, and thankfully that went smoothly. While I was doing that I thought that since I had the calipers off I might as well put on a set of PMB restored calipers. Since I was doing the calipers, I should also replace the soft brake lines. Mind you, the brake lines looked fine and the calipers were working fine. On those went without any problem. Since I had opened the system again I now had to bleed the brakes and another two quarts of brake fluid later I had a firm pedal and was satisfied there was no air in the system. Perfect, time to wrap it up and put the car back on the road but then my eye was caught by the Riviera's that came with the car, which I have never liked, and so I decided it was time to put on some nice Fuchs. Off came the wheels and tires, which were fine even if they are not IMO the most attractive, and on went a nice set of Fuchs with relatively new tires. When tightening up the lugs on the passenger side rear wheel I then noticed some play in the trailing arm. Well, a LOT of play in the trailing arm. Mind you I have never heard a clunk from the rear end, but this was a really obvious problem with the car up in the air. Off with the wheels again, off with the trailing arm (there was almost nothing left of the inner bushing), a trip to a friend's shop to use his press, and new bushings are in place. With the trailing arm out of the way it seemed like a good time to adjust the valves, so I got to work on that. I then had a prolonged struggle with a valve cover that just wouldn't go on again until I discovered that the problem was the hidden end of the bale had slipped out of it's retaining hole. That solved, and with the car still up in the air, and the brake system already having been opened, I thought I should replace the rear soft lines as well. After all I already had them. Those of you that have done this before know that the clip that holds on the forward end of the soft lines is pretty inaccessible. I struggled with that for a while before I realized that at the attachment for the bracket there are two small notches on either side that you can put the blade of a screwdriver in and then lever the clip forward and work it off. That accomplished I decided that since I would now need an alignment anyway now was the time to upgrade to turbo tie rods. That also necessitated sourcing a 32mm wrench and grinding the head down to fit on the turbo tie rods. While taking the old tie rods off I then noticed that the NEW MC was leaking from the Welsh plug. I had to walk away for a moment so back to the rear to reinstall the trailing arm which went smoothly except for gouging my head open on the sharp edge of the rear valence. Now I had to shift gears to my real profession, and a bit of wound care and closure, and calming down a worried wife, I was back to the car to finish off the rear end. So where I stand right now is the new ATE MC has arrived and I'm ready to start with that install, and then bleed the brakes for the THIRD time. I've had to stop myself from putting on new PMB rear calipers, replacing the trailing arm bushings on the driver's side, putting in new rear wheel bearings, and a variety of other "while I'm there" tasks. I'm not done yet, but today had to be a rest day as my hands are a bit sore and my wounds need some time to heal. I'm hoping the MC is a bit easier the second time around. I'm also hoping that scope creep doesn't take hold again! I have to say that even with the cost, time, aches, bruises, and flesh wounds I have really bonded with this car again, so there's at least that. I'm impressed if you actually read this far. I'm sure this progression rings familiar for those of us that wrench on our cars. Hopefully it was at least slightly amusing. |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 516 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
Well that's a "fun" and relatable story.
But, you know you won't stop thinking about those new calipers you should have installed, along with the left trailing arm bushings and the bearings. You know, if you skip "fixing" them. You should probably put on new parking brake cables or at least adjust them. How's that clutch cable holding up? Probably should at least check its adjustment. And since you have it up on the lift, now would be a perfect time to replace all those shifter bushings. Motor mounts? Tranny mounts? Pushrod tube seal leaks? Oil cooler seals? Etc. Etc. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th July 2025 - 07:23 PM |
