> Fuel Supply and Return Reversed?
s13u74cr4
post Jun 16 2024, 02:57 PM
I believe the PO of my 914 reversed the supply and return on the fuel lines when he swapped in SS lines. From reading other posts and diagrams the larger should be the supply I think. Believe this is backwards?
Zip tie is me trying to figure out what’s happening and get a decent photo and failing.
s13u74cr4
post Jun 16 2024, 06:22 PM
The larger SS line goes into that “Y”. For sure that plastic piece needs to be replaced.
I have not traced to the tank yet so no idea if that is correct. Any easy way to tell without taking too much apart?
The small line does go to the fuel filter then the top port on the fuel pump which is correct. Cramped and hard to see here.
- Lo-Fi Version Time is now: 19th July 2025 - 07:22 PM
