> Brain fart regulator question
mb911
post Jun 17 2024, 01:10 PM
So was noticing I have less voltage while the car is running. I am use to seeing 13/14 volts as the pretty much normal. I have a fairly new marchel alternator and this year I am seeing 13v on the high side. Now I do have more electrical items, wide band o2, mega squirt, and active exhaust. Regulator going bad? Pictured in upper left. Hmm maybe I have them on the wrong pins? Might have messed that up?Attached Image
rgalla9146
post Jun 17 2024, 01:19 PM
All consumers off ? Belt too loose ?
I can't describe how it's done but I understand there is a way to test output of an
alternator before the VR.
Maybe someone can chime in ?
mb911
post Jun 17 2024, 01:44 PM
QUOTE(rgalla9146 @ Jun 17 2024, 11:19 AM) *
That would be great if someone would. It would suck to have to change the alternator now
mb911   Brain fart regulator question   Jun 17 2024, 01:10 PM
rgalla9146   All consumers off ? Belt too loose ? I can...   Jun 17 2024, 01:19 PM
mb911   All consumers off ? Belt too loose ? I can...   Jun 17 2024, 01:44 PM
mlindner   Ben, why are using a remote regulator....Arn't...   Jun 17 2024, 02:06 PM
mb911   Ben, why are using a remote regulator....Arn...   Jun 17 2024, 02:14 PM
BillC   Wait ... someone makes a brain fart regulator? :b...   Jun 17 2024, 03:05 PM
mb911   Wait ... someone makes a brain fart regulator? :...   Jun 17 2024, 03:20 PM
bkrantz   Wait ... someone makes a brain fart regulator? :...   Jun 17 2024, 07:35 PM
windforfun   Since your regulator isn't part of your altern...   Jun 17 2024, 03:31 PM
mb911   Since your regulator isn't part of your alter...   Jun 17 2024, 04:39 PM
Artfrombama   Subscribed (FWIW) What are the normal voltages? A...   Jun 17 2024, 03:40 PM
Superhawk996   Ben, I’m on vacation with no access to my tech...   Jun 17 2024, 05:02 PM
mb911   Ben, I’m on vacation with no access to my tec...   Jun 17 2024, 05:21 PM
windforfun   "All I'm getting from my alternator is 13...   Jun 17 2024, 05:09 PM
mb911   "All I'm getting from my alternator is 1...   Jun 17 2024, 05:22 PM
windforfun   Let me clarify here. If your voltmeter reads 120 ...   Jun 17 2024, 05:25 PM
Superhawk996   Assuming you’re running a 3 pin mechanical regul...   Jun 17 2024, 05:27 PM
windforfun   :agree: :agree: :agree: This guy knows his shi...   Jun 17 2024, 05:37 PM
worn   Battery healthy? In some cases the alternator jus...   Jun 17 2024, 07:12 PM
mb911   Battery healthy? In some cases the alternator ju...   Jun 17 2024, 07:19 PM
Superhawk996   I’m going to post one more which is Spoke’s si...   Jun 17 2024, 05:48 PM
mb911   I’m going to post one more which is Spoke’s s...   Jun 17 2024, 07:21 PM
windforfun   :rotfl: :rotfl: :rotfl:   Jun 17 2024, 08:21 PM
Dave_Darling   Where are you taking the voltage reading from? If...   Jun 17 2024, 08:27 PM
mb911   Where are you taking the voltage reading from? I...   Jun 18 2024, 03:50 AM
rgalla9146   Ben your VR and Alt are both SEV Marshal...so shou...   Jun 17 2024, 09:23 PM
ClayPerrine   Ben, I would suggest running a "full field t...   Jun 18 2024, 02:44 AM
mb911   Ben, I would suggest running a "full field ...   Jun 19 2024, 07:10 AM
technicalninja   Ben, I would suggest running a "full field ...   Jun 18 2024, 06:36 AM
mb911   I want to quantify a few things. As rpm increases ...   Jun 18 2024, 07:17 AM
ClayPerrine   It’s like Texas up here not sure how you guys ...   Jun 18 2024, 08:16 AM
mb911   It’s like Texas up here not sure how you guys...   Jun 18 2024, 08:34 AM
Superhawk996   Just know that if you full field it - you will get...   Jun 18 2024, 08:47 AM
mb911   Just know that if you full field it - you will ge...   Jun 18 2024, 09:07 AM
mb911   So verified some basic connections and ohms tested...   Jun 18 2024, 03:39 PM
Superhawk996   dF is weird as I get different values depending ...   Jun 18 2024, 08:50 PM
mb911   dF is weird as I get different values depending...   Jun 19 2024, 04:21 AM
Spoke   dF is weird as I get different values depending on...   Jun 20 2024, 06:05 PM
mb911   dF is weird as I get different values depending o...   Jun 20 2024, 08:46 PM
mb911   Oh but the interesting thing is the battery light ...   Jun 18 2024, 04:42 PM
emerygt350   A hair off topic, and not to hijack, but why is th...   Jun 18 2024, 09:43 PM
Superhawk996   A hair off topic, and not to hijack, but why is t...   Jun 18 2024, 10:46 PM
emerygt350   A hair off topic, and not to hijack, but why is ...   Jun 19 2024, 07:49 PM
technicalninja   Not sure if this will help... The late model Miat...   Jun 19 2024, 07:27 AM
mb911   Not sure if this will help... The late model Mia...   Jun 19 2024, 07:34 AM
ClayPerrine   [quote name='technicalninja' post='3151786' date=...   Jun 20 2024, 05:15 AM
mb911   [quote name='technicalninja' post='3151786' date...   Jun 20 2024, 05:18 AM
ClayPerrine   [quote name='ClayPerrine' post='3151937' date='Ju...   Jun 20 2024, 01:28 PM
mb911   [quote name='ClayPerrine' post='3151937' date='J...   Jun 20 2024, 04:43 PM
Superhawk996   @emeryGT350 That doesn’t seem right. Let me ...   Jun 19 2024, 11:25 PM
technicalninja   I'm in agreement! I'd start with a st...   Jun 20 2024, 08:03 AM
JamesM   This wiring picture just broke my OCD   Jun 20 2024, 09:32 PM
mb911   This wiring picture just broke my OCD What...   Jun 21 2024, 04:48 AM
mb911   Well it was a combination of things. Ignition swit...   Jun 26 2024, 11:16 AM
SirAndy   Well it was a combination of things. Ignition swi...   Jun 26 2024, 12:48 PM
mb911   Well it was a combination of things. Ignition sw...   Jun 26 2024, 02:02 PM
Superhawk996   :trophy:   Jun 26 2024, 11:18 AM
- Lo-Fi Version Time is now: 6th July 2026 - 11:34 AM
