backfire through the carbs ..., makes for nice fireworks! |
SirAndy |
Jan 30 2005, 01:18 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
hey, it's me again, the "carb-hater" !!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
i've been trying to get this engine to run right for what now, 10 months??? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) i still have a issue with backfires upwards through the carbs (looks cool at night with the GT-engine lid) !!! now here's my question: - i'm still running stock (well, SSI) heat-exchangers and a close to stock (Manta) exhaust. - i have a cam with a lot of overlap. could the stock(ish) exhaust setup cause too much backpressure and the engine doesn't flow and belches back through the carbs ???? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy PS: this happens all over the rpm range, but more often under lower rpm load and higher rpm "cruise" (steady gas) and only sporadically at WOT ... |
r_towle |
Jan 30 2005, 06:43 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
my gut says valves are either sticking, rockers might be the wrong setup...etc.
I would take off the valve covers and verify everything moves correctly, verify with a guage for each valve... I might even go for a dial indicator to check the cam... If you bought this from a reputable builder I would not suggest this... Have you thought about the cam gear maybe not being bolted on correctly/tightly??? The other is wiring...I have had the same issue as above...a hidden bad/loose connection that made tha car run like crap only when hot and it skipped, sputtered and backfired out both ends... It was of all things a short in the tailight wiring harness that was shorting out the relay board just enough to throw off the whole system. Rich |
Lo-Fi Version | Time is now: 6th June 2024 - 05:20 AM |
