backfire through the carbs ..., makes for nice fireworks! |
SirAndy |
Jan 30 2005, 01:18 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
hey, it's me again, the "carb-hater" !!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
i've been trying to get this engine to run right for what now, 10 months??? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) i still have a issue with backfires upwards through the carbs (looks cool at night with the GT-engine lid) !!! now here's my question: - i'm still running stock (well, SSI) heat-exchangers and a close to stock (Manta) exhaust. - i have a cam with a lot of overlap. could the stock(ish) exhaust setup cause too much backpressure and the engine doesn't flow and belches back through the carbs ???? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy PS: this happens all over the rpm range, but more often under lower rpm load and higher rpm "cruise" (steady gas) and only sporadically at WOT ... |
tesserra |
Jan 30 2005, 08:03 PM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
Andy,
Did you try a manifold vacum gauge? If you have vacum you should not be able to push exhaust gases back thru the carbs. I too think it is a spark thing, maybe you have to retard the spark because of the overlap. It sounds like it is sparking with the intake partially open. Are your valves too tight for the overlap? Just ideas, but I think the vacum gauge will put the backpressure issue to rest. But if you want to use it as an reason to put on a new exhaust (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) it sounds good to me. George |
Lo-Fi Version | Time is now: 6th June 2024 - 11:53 AM |
