> Windshield wipers parking in middle of windshield WTH?!
DC_neun_vierzehn
post Mar 14 2024, 09:44 AM
From day one when I bought my 914 a couple of years ago, when I turned the wipers on, they would park wherever they were on the windshield when I turned the wiper switch to the off position (they would NOT go back to the normal park position at 9:00).
Thus, I had to keep turning the switch on and off until I got them where they should park at the bottom of the windshield at 9:00.
I thought replacing the wiper switch would do the trick. I installed a NOS SWF wiper switch and now the wipers go to a park position after turning the switch off, but that park position is at about 1:00. I tried removing the wiper arms and adjusting them to see if I could solve the problem, but no dice.
With the wiper arms removed, and the wiper switch in the off position, I should be able to install the wiper arms at the 9:00 position and when I turn the switch on they should operate properly.
But when I do that and turn the switch on, they go down onto the hood. In order to avoid the wipers from going onto the hood I have install them at the 1:00 position and when I turn the switch on they clean the whole windshield but park at 1:00 when the switch is in the off position.
What the heck is going on here?
It's almost like the PO installed the wiper motor backwards. Is that even possible?
DC_neun_vierzehn
post Jun 22 2024, 08:34 AM
Last question ...
Before I attempt to re-install the fresh air box, should I lube each of the joints on the replacement wiper assembly and motor? And if so, what lube specifically should I use (a link would be great)?
As I understand it, the old style grease attracts dirt, which will be counter productive and cause wear. Is there a proven new product that is dry, but keeps things lubed to reduce friction?
DC_neun_vierzehn
post Jun 23 2024, 08:07 AM
QUOTE(DC_neun_vierzehn @ Jun 22 2024, 08:34 AM) *
Last question ...
Maybe something like this?
https://www.amazon.com/gp/product/B000C17HK...X0DER&psc=1
DC_neun_vierzehn   Windshield wipers parking in middle of windshield WTH?!   Mar 14 2024, 09:44 AM
mrholland2   From day one when I bought my 914 a couple of yea...   Mar 14 2024, 10:34 AM
Root_Werks   I thought there was something that controlled the ...   Mar 14 2024, 11:07 AM
Superhawk996   Controlled by a rotating, cam shaped switch in the...   Mar 14 2024, 11:26 AM
ClayPerrine   The arm that drives the wipers is installed in the...   Mar 14 2024, 12:36 PM
DC_neun_vierzehn   The arm that drives the wipers is installed in th...   Mar 14 2024, 01:47 PM
ClayPerrine   The arm that drives the wipers is installed in t...   Mar 14 2024, 02:48 PM
914_teener   [quote name='DC_neun_vierzehn' post='3133758' dat...   Mar 14 2024, 02:51 PM
914_teener   The arm that drives the wipers is installed in th...   Mar 14 2024, 02:45 PM
bkrantz   The arm that drives the wipers is installed in th...   Mar 14 2024, 07:55 PM
DC_neun_vierzehn   The arm that drives the wipers is installed in th...   Jun 20 2024, 11:29 AM
ClayPerrine   [quote name='ClayPerrine' post='3133745' date='Ma...   Jun 20 2024, 01:23 PM
DC_neun_vierzehn   [quote name='ClayPerrine' post='3133745' date='M...   Jun 20 2024, 01:25 PM
rgalla9146   :agree: with Clay If you can get a long 10mm ...   Mar 14 2024, 07:40 PM
Dave_Darling   He's not talking about the wiper arms. He...   Mar 14 2024, 08:19 PM
fixer34   As noted, that is also what you do if you want to ...   Mar 14 2024, 08:26 PM
DC_neun_vierzehn   Ok. Finally getting around to addressing my wipers...   Jun 19 2024, 10:32 AM
DC_neun_vierzehn   I’m guessing I have to get it from inside the ca...   Jun 19 2024, 10:47 AM
Olympic 914   http://www.914world.com/bbs2/index.php?sho...=3049...   Jun 19 2024, 11:05 AM
DC_neun_vierzehn   http://www.914world.com/bbs2/index.php?sho...=304...   Jun 19 2024, 12:36 PM
DC_neun_vierzehn   This video helped me figure it out (from around th...   Jun 19 2024, 02:57 PM
DC_neun_vierzehn   Here is the access point (speedo removed and looki...   Jun 19 2024, 04:10 PM
DC_neun_vierzehn   Last question ... Before I attempt to re-install...   Jun 22 2024, 08:34 AM
DC_neun_vierzehn   Last question ... Before I attempt to re-instal...   Jun 23 2024, 08:07 AM
- Lo-Fi Version Time is now: 15th November 2025 - 01:53 PM
