> Boxster "S" 6 speed trans
partwerks
post Oct 5 2019, 02:50 PM
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine?
tygaboy
post Oct 6 2019, 09:12 AM
I'd bet that Tony has the market cornered on stress testing the Renegade mount. Between the LS3 and now the LS7, and the serious pace he runs on track, his mount has seen stresses that exceed what a typical street car will see.
Also, there are any number of LS-powered Renegade-based cars out there and I don't believe there are reported failures. I could be wrong, but I haven't heard of any.
Could other designs be "better"? There's always room to improve and Clay's is very nice. If one is a skilled fabricator, or has access to one, then sure, go for it.
But so far, so good on the Renegade design. I'll report back if I have any problems with mine - which has a 1.5" spacer added to it. So I'm likely the best test case for the "too much cantilever" study.
Lof8
post Jul 2 2024, 01:01 PM
QUOTE(tygaboy @ Oct 6 2019, 11:12 AM) *
Would you happen to have a photo of what this spacer looks like? I need to shift my boxster S trans 1.5" forward to put the Honda k24 where I want it and I'd like to see what you did. Thanks!
partwerks   Boxster "S" 6 speed trans   Oct 5 2019, 02:50 PM
tygaboy   The Boxster S trans is the G86-20. All of those ha...   Oct 5 2019, 03:38 PM
partwerks   The Boxster S trans is the G86-20. All of those h...   Oct 13 2019, 03:16 PM
Cracker   Lyle, I replied to your PM...the system is amazin...   Oct 5 2019, 07:21 PM
partwerks   Lyle, I replied to your PM...the system is amazi...   Oct 5 2019, 08:48 PM
ClayPerrine   I have a 2006 Cayman S G86-21 trans in my car. It...   Oct 5 2019, 09:10 PM
partwerks   Any pictures of what trans mount Renegade Hybrids ...   Oct 5 2019, 09:50 PM
Joemo5   Any pictures of what trans mount Renegade Hybrids...   Oct 5 2019, 10:33 PM
Cracker   1) If there IS one downside of the Renegade mount ...   Oct 6 2019, 06:56 AM
tygaboy   I'd bet that Tony has the market cornered on s...   Oct 6 2019, 09:12 AM
Lof8   But so far, so good on the Renegade design. I...   Jul 2 2024, 01:01 PM
dakotaewing   Tony and Clay, What did each of you do to address...   Oct 6 2019, 11:00 AM
Cracker   I have not seen a used box posted for sale that di...   Oct 6 2019, 11:24 AM
tygaboy   Lyle - If you mean the shifter and associated cabl...   Oct 6 2019, 03:11 PM
partwerks   Lyle - If you mean the shifter and associated cab...   Oct 6 2019, 03:33 PM
tygaboy   What is the numberic shifter? [/quote] This ...   Oct 6 2019, 06:33 PM
partwerks   Lyle - If you mean the shifter and associated cab...   Oct 6 2019, 05:36 PM
dakotaewing   Tony and Clay, The parts that I'm referring t...   Oct 6 2019, 04:45 PM
Cracker   Here you go Thom...allot less than $500! ...   Oct 6 2019, 05:23 PM
dakotaewing   Tony, I have the shift linkage indicated in the s...   Oct 6 2019, 06:01 PM
Cracker   I do not have those pieces on my box...it looks li...   Oct 6 2019, 06:41 PM
914forme   Generally the same, slight difference in CV flange...   Oct 6 2019, 06:03 PM
partwerks   Generally the same, slight difference in CV flang...   Oct 6 2019, 08:15 PM
FL 000   Generally the same, slight difference in CV flan...   Oct 8 2019, 07:45 PM
ClayPerrine   The G86-21 transmission has different cable attach...   Oct 6 2019, 06:30 PM
partwerks   I'm guessing that the adapter plate I have for...   Oct 7 2019, 08:46 PM
Cracker   Ok. I called Kennedy Engineering today for you...I...   Oct 8 2019, 05:44 PM
partwerks   Ok. I called Kennedy Engineering today for you......   Oct 8 2019, 07:23 PM
andys   Ok. I called Kennedy Engineering today for you.....   Oct 9 2019, 09:28 AM
partwerks   [quote name='partwerks' post='2753284' date='Oct ...   Oct 9 2019, 06:28 PM
dakotaewing   I must be getting old... $650 for a mass prod...   Oct 11 2019, 03:11 PM
partwerks   I must be getting old... $650 for a mass pro...   Oct 11 2019, 06:22 PM
Robarabian   Okay.. someone knew this was going to get asked......   Oct 8 2019, 07:31 PM
914forme   yes it has been done   Oct 8 2019, 07:43 PM
partwerks   yes it has been done These pictures are of a 6 ...   Oct 8 2019, 07:50 PM
Cracker   Good luck. Cracker   Oct 9 2019, 06:39 PM
Tdskip   Nothing to add except WOW guys, some neat engineer...   Oct 10 2019, 06:19 AM
partwerks   Would this clutch work, or is it heavy enough? ht...   Oct 11 2019, 09:20 PM
Mike Bellis   There are two (2) different 6 speed bellhousing bo...   Oct 13 2019, 10:24 PM
SirAndy   Embrace the suck... :D   Oct 14 2019, 02:37 PM
tygaboy   @Lof8 Here you go. A chunk of aluminum that was s...   Jul 2 2024, 03:16 PM
cooler   It's good to see this thread revived. I am usi...   Jul 2 2024, 05:13 PM
Wdrdb   It's good to see this thread revived. I am us...   Aug 8 2024, 11:06 PM
Lof8   @tygaboy that is nice solution that I hadn’t e...   Jul 3 2024, 04:43 AM
tygaboy   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 3 2024, 06:52 AM
Lof8   @tygaboy Your spacers could be exactly what I nee...   Jul 3 2024, 07:02 AM
tygaboy   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 3 2024, 03:50 PM
Lof8   I’ll reach out if 1.5” ends up being my magic ...   Jul 3 2024, 06:27 PM
Lof8   Hey 6-speeders, anyone have photos of how they pen...   Aug 1 2024, 07:52 AM
tygaboy   Hey 6-speeders, anyone have photos of how they pe...   Aug 1 2024, 08:14 AM
technicalninja   [b]@[url=http://www.914world.com/bbs2/index.php...   Aug 1 2024, 08:23 AM
ClayPerrine   I ran one of mine through the speedo cable hole, a...   Aug 1 2024, 01:46 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 04:24 AM
