| 930cabman |
May 8 2024, 05:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,873 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
My /6 conversion is going on 3 years as it seems as many do. I had a local old school reputable shop build the stock 2.7, case was done at Ollies, .... should be a great engine. Finally trying to get her barking, but just won't take hold. While cranking she wants to start, but when I release the starter, she conks out. We have a spark (not real significant), timing is close, carbs appear ok.
Is it possible the valves or maybe rings are not sealing because the engine sat for about 2 years? |
| rudedude |
Jul 8 2024, 11:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
Other 911 owners have had issues with oil filters that are not oem. Beware of knock offs!
| mb911 |
Jul 8 2024, 12:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,829 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
| 930cabman |
Jul 8 2024, 01:35 PM
Other 911 owners have had issues with oil filters that are not oem. Beware of knock offs! Mahle is no longer German made and we are seeing the results now I would like to think the major manufacturers would have QC in place when they move operations to other countries, maybe not. I'm going with this one in the future: https://www.napaonline.com/en/search?text=n...&referer=v2 Still can't believe I got a bad one that would not allow oil to enter (IMG:style_emoticons/default/idea.gif) |
930cabman Fresh 2.7 May 8 2024, 05:23 PM
Superhawk996 Fuel
Compression
Spark
Something is missing or... May 8 2024, 05:29 PM
930cabman
Fuel
Compression
Spark
Something is missing o... May 9 2024, 06:01 AM
technicalninja Run a compression test. If low add 1/2 oz of ATF/W... May 8 2024, 05:36 PM
mepstein Don’t panic, it’s usually something simple.
... May 8 2024, 05:46 PM
nditiz1 Can you confirm fuel is getting down the throats w... May 8 2024, 06:49 PM
930cabman
Can you confirm fuel is getting down the throats ... May 9 2024, 05:47 AM
Luke M
[quote name='nditiz1' post='3144117' date='May 8 ... May 9 2024, 05:54 AM
930cabman
[quote name='930cabman' post='3144161' date='May ... May 9 2024, 06:05 AM
flyer86d I had the same issue with the 2.7 that I put toget... May 9 2024, 05:05 AM
930cabman
I had the same issue with the 2.7 that I put toge... May 9 2024, 05:56 AM
flyer86d
I had the same issue with the 2.7 that I put tog... May 9 2024, 02:52 PM
930cabman
[quote name='930cabman' post='3144165' date='May ... May 9 2024, 03:40 PM
mb911 Ok so I will echo wrong cam timing. A friend bough... May 9 2024, 06:04 AM
Retroracer @930cabman - hope recovery from the health issues... May 9 2024, 08:26 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 9 2024, 09:37 AM
gereed75 Incorrect fuel level in carbs can result in a no g... May 9 2024, 08:31 AM
930cabman
Incorrect fuel level in carbs can result in a no ... May 9 2024, 09:40 AM
Root_Werks Would certainly do a simple compression test, just... May 9 2024, 10:00 AM
Superhawk996
Would really hope the cams are not 180 out. :(
... May 9 2024, 01:06 PM
930cabman
Would certainly do a simple compression test, jus... May 9 2024, 01:14 PM
mb911
Would certainly do a simple compression test, ju... May 9 2024, 01:17 PM
Root_Werks
Would certainly do a simple compression test, ju... May 9 2024, 03:44 PM
flyer86d
[quote name='930cabman' post='3144246' date='May ... May 10 2024, 05:42 AM
technicalninja Running the compression test WILL verify cam timin... May 9 2024, 01:45 PM
930cabman
Running the compression test WILL verify cam timi... May 9 2024, 03:37 PM
gereed75 I had the exact same symptoms.
Changed the igniti... May 10 2024, 08:20 AM
930cabman
Changed the ignit... May 10 2024, 08:59 AM
930cabman Checked power at the coil + terminal, solid 12volt... May 23 2024, 12:28 PM
Root_Werks
Checked power at the coil + terminal, solid 12vol... May 23 2024, 12:41 PM
930cabman I have noticed a rather large (more than I am used... May 23 2024, 03:36 PM
Geezer914 Any possibility of a vacuum leak? May 23 2024, 03:44 PM
930cabman
Thanks, but i... May 25 2024, 01:26 PM
Superhawk996
Thanks, but ... May 25 2024, 01:51 PM
930cabman
[quote name='930cabman' post='3147314' date='May ... May 25 2024, 04:38 PM
IronHillRestorations I’m going to guess the distributor timing is inc... May 25 2024, 06:45 PM
thomasotten Distributor firing order. May 25 2024, 07:10 PM
930cabman Checking ohms across the + battery cable (when dis... May 26 2024, 07:27 AM
Superhawk996
Checking ohms across the + battery cable (when di... May 26 2024, 07:48 AM
930cabman
Checking ohms across the + battery cable (when d... May 26 2024, 08:09 AM
mlindner I moved the battery to the trunk. Then fabricated ... May 26 2024, 08:27 AM
930cabman
I moved the battery to the trunk. Then fabricated... May 26 2024, 10:17 AM
Superhawk996 Got it.
Agree the 170 ohms on the /6 is not ide... May 26 2024, 10:20 AM
930cabman
Got it.
Agree the 170 ohms on the /6 is not id... May 26 2024, 04:44 PM
mb911
Got it.
Agree the 170 ohms on the /6 is not i... May 26 2024, 05:05 PM
windforfun "Ohms law: 12v / 170 ohms = .071 amps of para... May 26 2024, 05:47 PM
Superhawk996
Hmmm... 71 mA is enough to kill you. IMHO, thi... May 26 2024, 08:43 PM
930cabman I sense the compression is good based on the sound... May 26 2024, 06:02 PM
mb911
I sense the compression is good based on the soun... May 26 2024, 07:36 PM
Superhawk996
I sense the compression is good based on the sou... May 26 2024, 08:23 PM
technicalninja windforfun, thought you are an EE Sir!
It... May 26 2024, 06:04 PM
930cabman
It... May 26 2024, 06:21 PM
windforfun
It... May 26 2024, 07:19 PM
technicalninja I'll put the draw issue to bed with this...
A... May 26 2024, 07:15 PM
Superhawk996
The draw is a "red herring" in the tro... May 26 2024, 08:49 PM
technicalninja Just remembered a stock 914 parasitic draw...
Only... May 26 2024, 09:14 PM
Superhawk996
Onl... May 26 2024, 09:21 PM
930cabman ON TO SOMETHING
as you can imagine, this driving ... May 27 2024, 06:02 AM
930cabman She lives :Qarl:
Spark timing was retarded by ... May 29 2024, 02:54 PM
mate914
She lives :Qarl:
Spark timing was retarded by... May 29 2024, 07:27 PM
930cabman
She lives :Qarl:
Spark timing was retarded b... May 30 2024, 04:55 AM
930cabman
She lives :Qarl:
Spark timing was retarded b... Jul 7 2024, 08:37 AM
mate914
[quote name='mate914' post='3148162' date='May 29... Jul 7 2024, 09:00 AM
Root_Werks Very glad this had a happy ending! Or rather ... May 30 2024, 09:29 AM
930cabman Thank you to all contributors, she is running dece... May 30 2024, 03:14 PM
flyer86d As I found out on my 2.7, set up the Webers on ini... May 30 2024, 03:32 PM
930cabman
As I found out on my 2.7, set up the Webers on in... May 31 2024, 08:08 AM
IronHillRestorations @930cabman check your oil lines. Sounds like you ... Jul 7 2024, 09:08 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 7 2024, 11:58 AM
mate914
[b]@[url=http://www.914world.com/bbs2/index.php?... Jul 7 2024, 12:22 PM
sixnotfour the bypass for the oil filter is in the console ,,... Jul 7 2024, 09:13 AM
sixnotfour top right, Jul 7 2024, 09:23 AM
mb911 What console do you have? I have seen reports on t... Jul 7 2024, 09:46 AM
930cabman
What console do you have? I have seen reports on ... Jul 7 2024, 11:57 AM
930cabman What appears to be some sort of pressure valve ins... Jul 7 2024, 02:35 PM
mb911
What appears to be some sort of pressure valve in... Jul 7 2024, 02:47 PM
930cabman Been wrenching for 50+ years, never seen an oil fi... Jul 7 2024, 03:20 PM
sixnotfour is this an oc 54..not the early filter. Jul 7 2024, 03:51 PM
930cabman
If memo... Jul 7 2024, 03:56 PM
sixnotfour
If mem... Jul 7 2024, 04:00 PM
mb911
[quote name='mb911' post='3155387' date='Jul 8 20... Jul 8 2024, 01:46 PM
technicalninja Seeing no oil at all in the filter would bug the c... Jul 8 2024, 02:10 PM
930cabman
Seeing no oil at all in the filter would bug the ... Jul 8 2024, 03:10 PM
mb911 http://forums.pelicanparts.com/porsche-911...oil-f... Jul 8 2024, 02:23 PM
930cabman
http://forums.pelicanparts.com/porsche-911...oil-... Jul 8 2024, 03:19 PM
930cabman https://mahle.integrityplatform.org/
Wonder if th... Jul 8 2024, 03:24 PM
mate914
Wonder if t... Jul 8 2024, 06:24 PM
930cabman
[quote name='930cabman' post='3155427' date='Jul ... Jul 8 2024, 07:00 PM
930cabman No good
Appears some sort of valve has found i... Jul 9 2024, 01:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 08:58 AM |
