Stef914 |
human ![]() ![]() Group: Members Posts: 96 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California ![]() |
Hi all,
I've recently purchased a set of black steelies here: https://www2.cip1.com/acc-c10-6623-mb/ I'm trying to understand if 205/60 R15 tires will fit without rubbing the fenders. My car is stock, and I currently have stock Fuchs wheels, also with 205/60 R15 tires on. I know that the stock Fuchs are: 15 inches in diameter Have a width of 5.5 inches With a bolt pattern of 4x130 mm An offset (ET) of +40 mm An approximate backspacing of 109.85 mm or roughly 4.32 inches And I know that the steelies are: 15 inches in diameter With a width of 5.5 inches With a bolt pattern of 4x130 An offset (ET) of +25 mm An approximate backspacing of 108 mm or roughly 4.25 inches I unsuccessfully reached out to @80'soldschool! who in 2019 started a thread with the very same steel wheels but 6 inches wide rather than 5.5" and was running 195/55/15, but I wasn't able to get an answer from him... http://www.914world.com/bbs2/index.php?showtopic=339828 Anyway, I'm okay with mounting 195/55/15, but I'd rather go with 205/60 R15 if that works... So, to make a long story short, if any of you have the very same wheels with 205s on, would you be so kind as to let me know? This way, I'll be 100% sure they'll fit. Otherwise, I'm also wondering what your take on the correct size might be. As always, thanks so much for your help! |
Lo-Fi Version | Time is now: 5th July 2025 - 06:12 AM |
