Stef914 |
human ![]() ![]() Group: Members Posts: 96 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California ![]() |
Hi all,
I've recently purchased a set of black steelies here: https://www2.cip1.com/acc-c10-6623-mb/ I'm trying to understand if 205/60 R15 tires will fit without rubbing the fenders. My car is stock, and I currently have stock Fuchs wheels, also with 205/60 R15 tires on. I know that the stock Fuchs are: 15 inches in diameter Have a width of 5.5 inches With a bolt pattern of 4x130 mm An offset (ET) of +40 mm An approximate backspacing of 109.85 mm or roughly 4.32 inches And I know that the steelies are: 15 inches in diameter With a width of 5.5 inches With a bolt pattern of 4x130 An offset (ET) of +25 mm An approximate backspacing of 108 mm or roughly 4.25 inches I unsuccessfully reached out to @80'soldschool! who in 2019 started a thread with the very same steel wheels but 6 inches wide rather than 5.5" and was running 195/55/15, but I wasn't able to get an answer from him... http://www.914world.com/bbs2/index.php?showtopic=339828 Anyway, I'm okay with mounting 195/55/15, but I'd rather go with 205/60 R15 if that works... So, to make a long story short, if any of you have the very same wheels with 205s on, would you be so kind as to let me know? This way, I'll be 100% sure they'll fit. Otherwise, I'm also wondering what your take on the correct size might be. As always, thanks so much for your help! |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,009 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Every car has different rear fender clearance. Hand assembled
So one persons answer does not guarantee it will fit your car Might fit 205 But no one on this board can answer that question exactly Depends on your car Only way to know is to try |
Lo-Fi Version | Time is now: 5th July 2025 - 06:27 AM |
