> Brake Lines
TINKERGINEERING
post Jul 29 2024, 01:56 PM
Ok so brake lines are next in my restoration. Is it a good idea to try and bend my own stainless steel brake lines? There is probably a thread already on this, but I haven't found it (Let me know if there indeed is one). But have any of you had success with this? Drop any tips below
thanks-
Frances
Chris914n6
post Jul 29 2024, 03:10 PM
Jackstands are my life.
Suprisingly Autozone sells all the pieces to DIY brake lines. Doesn't need to be stainless to do the job. The tools are cheap and it's not complicated.
When I removed the VW engine and the shelves it left the brake lines in precarious places, plus I removed the giant brake prop valve, so I needed lines that fit better.
If you don't need to modify the lines then PMB pre-made might be a better way to go.
I never did find new plastic retainer clips.
TINKERGINEERING   Brake Lines   Jul 29 2024, 01:56 PM
Shivers   Ok so brake lines are next in my restoration. Is ...   Jul 29 2024, 02:12 PM
fixer34   Ok so brake lines are next in my restoration. Is ...   Jul 29 2024, 02:16 PM
technicalninja   :agree: :agree: :agree:   Jul 29 2024, 02:16 PM
friethmiller   :agree: I went with the Stainless from PMB.   Jul 29 2024, 02:22 PM
Chris914n6   Suprisingly Autozone sells all the pieces to DIY b...   Jul 29 2024, 03:10 PM
bdstone914   Stainless steel is not needed or easy to form the ...   Jul 29 2024, 03:38 PM
bkrantz   Stainless steel is not needed or easy to form the...   Jul 29 2024, 07:27 PM
fixer34   Stainless steel is not needed or easy to form th...   Jul 30 2024, 06:25 AM
bkrantz   [quote name='bkrantz' post='3159220' date='Jul 29...   Aug 21 2024, 07:22 PM
Maltese Falcon   914 uses a spec 'Double flare at the ends= whi...   Jul 29 2024, 07:56 PM
technicalninja   Frances, Having the skill to create high pressure ...   Jul 29 2024, 08:04 PM
technicalninja   Double post, sorry!   Jul 29 2024, 08:05 PM
Superhawk996   +1 steel lines and buy them. Bubble flares aren’...   Jul 30 2024, 07:48 AM
worn   +1 steel lines and buy them. Bubble flares arenâ€...   Aug 21 2024, 08:58 PM
mepstein   You and Eric are buddies. I can’t imagine why yo...   Jul 30 2024, 08:17 AM
Robarabian   Frances, You did me a solid on a contest a while ...   Jul 30 2024, 10:31 PM
mepstein   Frances, You did me a solid on a contest a while...   Jul 31 2024, 05:18 AM
76-914   I'm going to play the Devil's Advocate her...   Jul 31 2024, 08:15 AM
Superhawk996   I'm going to play the Devil's Advocate he...   Jul 31 2024, 08:25 AM
76-914   I'm going to play the Devil's Advocate h...   Aug 20 2024, 09:38 PM
VaccaRabite   While I generally will back Eric/PMB - this time I...   Jul 31 2024, 08:58 AM
Dave_Darling   Perhaps another visit with PMB is in order? That ...   Jul 31 2024, 05:57 PM
mepstein   :)   Jul 31 2024, 06:23 PM
technicalninja   :agree: Add one more line $500 per hour if...   Jul 31 2024, 07:13 PM
TINKERGINEERING   Haha thanks guys! I took a break from thinking...   Aug 20 2024, 09:02 PM
willieg   IMHO, Copper nickel brake lines are much easier to...   Aug 20 2024, 10:00 PM
worn   IMHO, Copper nickel brake lines are much easier t...   Aug 21 2024, 08:59 PM
Cairo94507   I bought a complete set of Eric's "green...   Aug 22 2024, 08:39 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:37 AM
