Anyone tried an aircooled Flat 8, With two fours? |
r_towle |
Jan 28 2005, 12:49 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions. Assumptions 2 motors each producing 100 HP and 100 Lb/ft of Torque The motors are end to end, front to rear. The cranks are fastened together either bolted or welded. 1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque.. 2) could it be done with a single ignition system available for sale off the shelf. 3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from. 4) I am assuming either a nice FI system, or four carbs. Has anyone done this? I would like to see some articles or web pages if this has been done in the aircooled world... Thanx in advance Rich |
r_towle |
Jan 31 2005, 05:28 PM
yes, but what if you welded up the two motors to be in the 90 degree position???
That is what I was thinking.... Rich |
