Will work for spacers...., i need ideas, these spacers no fit! |
xsboost90 |
Jan 31 2005, 06:55 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
well i got my 911 front suspension all installed and drilled rear hubs, but the wheels im using-i guess- are leaving me w/ some problems. I got a set of adapters and spacers from a friend of mine that WOULD work but im having troubles w/ them fitting. The front adapter/spacer is an inch and a half wide but the center is made to go onto the rear axel. It is a quality part from a 911 and is heavy dooty, but if i machine the center out to fit over the front hub center, will it be too weak? Does anyone have a spacer this wide for the front?
the rear spacers are just too wide, either i need longer studs-which i cant seem to find anywhere local, or i need smaller spacers. The spacing on the rear wheel isnt bad but could come out like 1/4 to 1/2" w/o a problem but these are 3/4" and just arent working. Im thinking 1/4" would work fine since my rotors are not on right now either. I need to get some five lug rotors or drill mine soon to check fitment.... Attached image(s) |
xsboost90 |
Jan 31 2005, 07:48 PM
ok, the spacing on the rear is actually pretty close to correct, i would say max i would need a 7mm spacer, what about muellers 3/8" spacers?..Does this mean i can keep those studs? No way im pulling them back out!
The front...if i can put those on a lathe and take off JUST enough to clear the hubs bearing cap, then would that seem to be OK? They are so damn thick i would think so, just wanna be safe. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:26 PM |
