| BigD9146gt |
Jan 31 2005, 07:59 PM
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
Hello all,
I'd like to get some feedback on these because I haven't made a whole bunch, but if theres more interest, i'll spend the dough... I have a few more in production, and these still need to get anodized, which is about a month or two away. For any of you who are looking to put Boxster calipers on your A or S 911 struts, here is a kit I've been working on. (IMG:http://forums.pelicanparts.com/uploads4/P10100021107205777.jpg) The front adapters are on the right, the GT rears are on the left. The reason i call the rears "GT" is because they use a rear Boxster rotor which has less inward offset than an SC or Carrera rear rotor. I'm currently reaching production of the 914/911 ('69-'89) rear (non-GT) adapters next week. Then off to anodizing, then for sale. The front adapters will work under a 15" rim. All offsets are for a stock, non 'S' Boxster '97-present. The front kit with bolts runs $300. (IMG:http://forums.pelicanparts.com/uploads4/P10100331107220300.jpg) The rear adapters 'non-GT', will use a 911SC rear rotor, and relocate the caliper to the top of the rotor for clearance reasons. The picture of this part is a rapid prototype done on a Z-Corp printer. I don’t have a picture of this mounted, but the two lower bolt holes allow bolts to hold this piece to the trailing arm, then the caliper bolts to the two threaded holes facing upward. This rear kit with bolts runs for $400 (IMG:http://forums.pelicanparts.com/uploads4/P10100041107220599.jpg) The rear adapters 'GT', will use a stock Boxster (non-'S') rear rotor. The issue with this setup is that the rotor is not as deep as the SC rear rotor, but has a larger rotor diameter to keep the caliper in the same location (not mounted on top like the non-GT kit). so the caliper's outer half sticks out slightly past the wheel mating surface, requiring a 7mm spacer to be added so that rims (like a 15" Fuchs) will clear the caliper. This rear kit with bolts runs for $300. (IMG:http://forums.pelicanparts.com/uploads4/P10100311107220268.jpg) Calipers, rotors, and pads can be aquired new from me, your favorite parts supplier, or any Porsche dismantler. |
Mueller looks nice...I hate people like you that actually ... Jan 31 2005, 08:06 PM
wrpspddrvr SCHWEET!!!!
Cole http://www.91... Jan 31 2005, 08:46 PM
vortrex that looks great! anyone know the differences... Jan 31 2005, 08:48 PM
BigD9146gt Aaron and Jim,
The problem with the M struts is t... Jan 31 2005, 08:52 PM
JmuRiz Here is the only pic I have, actually a crop job, ... Jan 31 2005, 10:54 PM
echocanyons Lookin good!
It suprises me how many of the ... Feb 1 2005, 12:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 05:53 PM |
