Will work for spacers...., i need ideas, these spacers no fit! |
xsboost90 |
Jan 31 2005, 06:55 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
well i got my 911 front suspension all installed and drilled rear hubs, but the wheels im using-i guess- are leaving me w/ some problems. I got a set of adapters and spacers from a friend of mine that WOULD work but im having troubles w/ them fitting. The front adapter/spacer is an inch and a half wide but the center is made to go onto the rear axel. It is a quality part from a 911 and is heavy dooty, but if i machine the center out to fit over the front hub center, will it be too weak? Does anyone have a spacer this wide for the front?
the rear spacers are just too wide, either i need longer studs-which i cant seem to find anywhere local, or i need smaller spacers. The spacing on the rear wheel isnt bad but could come out like 1/4 to 1/2" w/o a problem but these are 3/4" and just arent working. Im thinking 1/4" would work fine since my rotors are not on right now either. I need to get some five lug rotors or drill mine soon to check fitment.... Attached image(s) |
SirAndy |
Jan 31 2005, 08:05 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i always forget that most of you guys don't run open end lug nutz ... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Andy |
Lo-Fi Version | Time is now: 8th June 2024 - 12:45 AM |
