| torakki |
Aug 13 2024, 08:33 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
I finally got the '74 2.0L running well and went for a 20-to-30-minute drive. Temps were in the upper 80s and I'm not sure if the car was getting to hot.
Since there are no digits on the gage, I need to ask. I found a drawing of gages, so I think I'm in the 240 area. Not sure if the temp was still going to rise since I was back at home. The photo is from the passenger seat but from driver side, the "P" was mostly covered by the needle. Am I still in the safe area? Thanks for any knowledge on this. ![]() |
| technicalninja |
Aug 14 2024, 08:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
I'd want cylinder head temp as well. To me, CHT is more important than oil temp. 300 peak is fine for synthetics. 300 continuous would bug me Above 250 continuous on dino would be the same. Now, a track only car I'd hunt for lowest temps possible at all times. Oil dilution would not be an issue with 5–10-hour oil change intervals. Anything street based (long oil change interval) I'd WANT to see above 212 during every drive to reduce the moisture. |
torakki Oil temp question? Aug 13 2024, 08:33 PM
Superhawk996 You need to confirm what temp sending unit is in y... Aug 13 2024, 10:41 PM
930cabman You might want to pickup an IR temp sensor to doub... Aug 14 2024, 04:47 AM
Geezer914 I changed all the center console gauges to new VDO... Aug 14 2024, 05:23 AM
mb911 So I gonna stir the pot on this. What is a good av... Aug 14 2024, 07:19 AM
Superhawk996
I saw post the other day from Charles Navarro sta... Aug 14 2024, 07:49 AM
dr914@autoatlanta.com make sure that the bellows flaps are installed and... Aug 14 2024, 08:03 AM
Superhawk996 Lest anyone accuse me of just propagating my own m... Aug 14 2024, 08:09 AM
914Sixer As long as it is NOT in the red, nothing to worry ... Aug 14 2024, 09:47 AM
Superhawk996
As long as it is NOT in the red, nothing to worry... Aug 14 2024, 11:14 AM
930cabman I have the factory temp gauge and a capillary tube... Aug 14 2024, 10:12 AM
emerygt350 However ... If that is your oil temp, I would be c... Aug 14 2024, 03:39 PM
torakki OK. lots of great info. I do personally like the ... Aug 14 2024, 08:19 PM
wonkipop the thing about running at an ideal temp of 90C is... Aug 15 2024, 03:38 AM
emerygt350 The fi cht is not useful for engine monitoring. Y... Aug 15 2024, 04:44 AM
SKL1 When restoring my '73 2.0 several years ago I... Aug 15 2024, 11:08 AM
Dave_Darling Hopefully they sent you a sender that is calibrate... Aug 15 2024, 01:39 PM
BeatNavy Good thread and of interest to me.
Another data p... Aug 15 2024, 02:46 PM
emerygt350 Yeah, I like my low oil temps cause I hope they ca... Aug 15 2024, 06:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 10:15 PM |
