| torakki |
Aug 13 2024, 08:33 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
I finally got the '74 2.0L running well and went for a 20-to-30-minute drive. Temps were in the upper 80s and I'm not sure if the car was getting to hot.
Since there are no digits on the gage, I need to ask. I found a drawing of gages, so I think I'm in the 240 area. Not sure if the temp was still going to rise since I was back at home. The photo is from the passenger seat but from driver side, the "P" was mostly covered by the needle. Am I still in the safe area? Thanks for any knowledge on this. ![]() |
| torakki |
Aug 14 2024, 08:19 PM
OK. lots of great info. I do personally like the "If it's not in the red" simple answer. Looks like I need to research a little on what I have on the car. I really don't want to dig into the sender risking oil leaks I'm trying to reduce currently.
One comment mentioned the flaps which I know, I need to check to see if they're open. And the heater plumbing is there. CHT sensor I believe is now disconnected sine I switched over to carbs. And the guy that switched the carbs also changed the oil so don't recall what he said he put in. Superhawk showing the book makes me feel more comfortable, that a normal, high temp would be 248 and, if my sender matches the gage, I'm under the high mark. I need to go for another, longer, drive and test more. It's been hot in my area and no A/C in the 914 with me getting a little older. Gotta wait a few days. BTW - "How's it run" = I posted her in the past on getting the FI to work right. 3 shops and I couldn't do it so went to carbs, now runs very well. Seems the FI had snappier throttle response, but the carbs make it "drivable". Thanks for all the responese and great info. |
torakki Oil temp question? Aug 13 2024, 08:33 PM
Superhawk996 You need to confirm what temp sending unit is in y... Aug 13 2024, 10:41 PM
930cabman You might want to pickup an IR temp sensor to doub... Aug 14 2024, 04:47 AM
Geezer914 I changed all the center console gauges to new VDO... Aug 14 2024, 05:23 AM
mb911 So I gonna stir the pot on this. What is a good av... Aug 14 2024, 07:19 AM
Superhawk996
I saw post the other day from Charles Navarro sta... Aug 14 2024, 07:49 AM
dr914@autoatlanta.com make sure that the bellows flaps are installed and... Aug 14 2024, 08:03 AM
technicalninja :agree:
I'd want cylinder head temp as well.... Aug 14 2024, 08:09 AM
Superhawk996 Lest anyone accuse me of just propagating my own m... Aug 14 2024, 08:09 AM
914Sixer As long as it is NOT in the red, nothing to worry ... Aug 14 2024, 09:47 AM
Superhawk996
As long as it is NOT in the red, nothing to worry... Aug 14 2024, 11:14 AM
930cabman I have the factory temp gauge and a capillary tube... Aug 14 2024, 10:12 AM
emerygt350 However ... If that is your oil temp, I would be c... Aug 14 2024, 03:39 PM
wonkipop the thing about running at an ideal temp of 90C is... Aug 15 2024, 03:38 AM
emerygt350 The fi cht is not useful for engine monitoring. Y... Aug 15 2024, 04:44 AM
SKL1 When restoring my '73 2.0 several years ago I... Aug 15 2024, 11:08 AM
Dave_Darling Hopefully they sent you a sender that is calibrate... Aug 15 2024, 01:39 PM
BeatNavy Good thread and of interest to me.
Another data p... Aug 15 2024, 02:46 PM
emerygt350 Yeah, I like my low oil temps cause I hope they ca... Aug 15 2024, 06:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 10:16 PM |
