> gear shift
Petepat
post Aug 14 2024, 12:00 PM
So my side shift gear lever is very sloppy (what's new!) sorted the rear end and much improved but replacing the 2 bushes at the front end is proving mysterious! The spring that pushes the gear lever up into it's surrounding socket still leaves about nearly a quarter inch vertical play ie the top bush doesn't seem to want to go all the way up and take up the slack! Is this what's supposed to happen or does it need to be driven in somehow? I'm sure someone has been here before me, all suggestions welcomed.
Petepat
post Aug 15 2024, 01:13 AM
I have that spring arrangment you show and no the ball does not sit tight up against the cup, there's maybe nearly a quarter inch gap. It seems that the plastic bush doesn't want to go all the way up to support the ball?!
- Lo-Fi Version Time is now: 10th March 2026 - 05:02 AM
