| Petepat |
Aug 14 2024, 12:00 PM
Member ![]() ![]() Group: Members Posts: 75 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
So my side shift gear lever is very sloppy (what's new!) sorted the rear end and much improved but replacing the 2 bushes at the front end is proving mysterious! The spring that pushes the gear lever up into it's surrounding socket still leaves about nearly a quarter inch vertical play ie the top bush doesn't seem to want to go all the way up and take up the slack! Is this what's supposed to happen or does it need to be driven in somehow? I'm sure someone has been here before me, all suggestions welcomed.
| Petepat |
Aug 15 2024, 04:40 AM
Problem solved but am I loosing it! The spring was reversed so that the top bush which is bigger than the lower bush would not take up the slack in the ball cup! Took me quite a while to tumble that! but thank you for your prompt replies (IMG:style_emoticons/default/beerchug.gif)
Petepat gear shift Aug 14 2024, 12:00 PM
Shivers
So my side shift gear lever is very sloppy (what... Aug 14 2024, 12:42 PM
Petepat
[quote name='Petepat' post='3161994' date='Aug 14... Aug 14 2024, 03:13 PM
Shivers
[quote name='Petepat' post='3161994' date='Aug 1... Aug 14 2024, 04:09 PM
Petepat I have that spring arrangment you show and no the ... Aug 15 2024, 01:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 05:02 AM |
