| Literati914 |
Aug 13 2024, 06:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have a set of 4 into 1 stainless headers that I want to connect up with an old stainless steel 1in-2out Tangerine muffler. The muffler was obviously not made for this header system but they are not that far off either. Well a little is a lot in this case I guess.
I have a MIG welder and thought I’d buy some self-shielded stainless wire (rather than invest in a whole tank of gas), and try to fix the gap. If nothing else I figured I could tack up a solution and let a real welder finish it (if blowing holes became unavoidable). I’ve found that the tube exiting the muffler is apparently made up of mild steel at the flange (magnet sticks strongly), then the curved mid-section of the tube is a low carbon steel (magnet sticks BUT NOT strongly), then the very short part is all stainless as is the rest of the muffler (magnet does not stick). I’m looking for suggestions as to where you guys would cut, maybe good only spots to buy pre-curved stainless or what to search for. General suggestions would be appreciated. Part of wanting to take on this task is that I’d like to add to my welding experience if I can. Here are some pics of the project: Attached image(s)
| Shivers |
Aug 15 2024, 07:53 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,203 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Sorry but I have to ask, are you not defeating the reason for a header in the first place but choking it off at the muffler inlet pipe? Maybe you could knock a piece of wood into the inlet pipe and run a hole saw to get a bigger hole in the muffler and then weld in a pipe that is closer to the diameter of the header outlet? Just curious about the reduction
@Literati914 ![]() |
Literati914 1-in/2-out Muffler input needs alteration Aug 13 2024, 06:31 PM
Literati914 Another view Aug 13 2024, 06:32 PM
Literati914 Another view again Aug 13 2024, 06:33 PM
Literati914 At the header, I’ve actually slid the collector ... Aug 13 2024, 06:37 PM
mb911 Ok there is no way that muffler is stainless as it... Aug 14 2024, 03:54 AM
ChrisFoley I think the muffler inlet was altered by someone e... Aug 14 2024, 04:57 AM
mb911
I think the muffler inlet was altered by someone ... Aug 14 2024, 07:08 AM
infraredcalvin :agree: cut in 2 places where shown, you have to e... Aug 14 2024, 08:11 AM
Literati914 Right, your suggestions are along the lines of wha... Aug 14 2024, 10:43 AM
infraredcalvin Googling, apparently it’s called an ‘s‘ bend... Aug 14 2024, 11:31 AM
TonyVan Is it possible to bolt the muffler to the header a... Aug 14 2024, 04:26 PM
Literati914
Is it possible to bolt the muffler to the header ... Aug 14 2024, 04:46 PM
Literati914 Ok well I made the cut at the muffler end of the c... Aug 14 2024, 07:47 PM
Literati914 Also drove the collector up to where it’s suppos... Aug 14 2024, 07:48 PM
Literati914 Now I can see the situation better..
if I now mak... Aug 14 2024, 07:51 PM
Literati914 Looks like only a 1/2”- 3/4” filler piece of s... Aug 14 2024, 07:52 PM
ChrisFoley I would still make the second cut where infraredca... Aug 15 2024, 07:31 AM
Flyinlow
Sorry but I have to ask, are you not defeating th... Aug 15 2024, 08:12 AM
ChrisFoley Actually, the inexpensive collector is far from op... Aug 15 2024, 12:38 PM
Literati914
Sorry but I have to ask, are you not defeating th... Aug 16 2024, 11:53 AM
Shivers
Sorry but I have to ask, are you not defeating t... Aug 16 2024, 02:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 05:01 PM |
