> 914 Gas Tank condition, Is my tank OK?
Dugo16
post Aug 16 2024, 12:50 AM
How does the inside of my gas tank look to you guys? Do I need to clean and seal it or leave it as is? Thanks, DougAttached Image
Superhawk996
post Aug 16 2024, 06:49 AM
Never seal gas tanks, that (IMG:style_emoticons/default/stromberg.gif) eventually flakes off and then you’ll really be hating life. If it needs to be sealed, it needs to be replaced.
POR metal prep was what I used on mine. It’s phosphoric acid (removes the surface rust) with a zinc additive in it that helps reduce the flash rusting (yellow rust) when drying and leaves a light zinc coating that helps prevent future surface rust.
https://por15.com/a/s/products/metal-prep
To reiterate, you couldn’t pay me to use POR or anyone else’s tank sealer.
Marks suggestion of Vinegar is cheaper and will work - just a bit slower than Phosphoric acid.
Reverse electrolysis also works great but literally can take multiple days and cleanings of the electrode.
bkrantz
post Aug 16 2024, 07:58 PM
QUOTE(Superhawk996 @ Aug 16 2024, 06:49 AM) *
I agree, I found an old fashioned shop in Tucson to "boil out" my tank (really just a very caustic fluid bath). Those guys were VERY clear. A new or cleaned out tank does not need coating, and should never be coated.
You can also use muriatic acid to dissolve rust and crud.
But be very careful if you see any rust, inside or especially on the outer surface, that the tank metal has weakened or even could leak.
- Lo-Fi Version Time is now: 15th April 2026 - 02:04 PM
