> MPS Inductance Curves and Tuning, Is Fuel Injection Corp USA Selling Rebuilt MPSs with Bad Transformers?
Cessnaporsche01
post Apr 15 2024, 11:06 AM
So a lot of you will remember my thread from last year that ran for many many pages, trying to get my '74 2.0(56) running again after literal years of turmoil and confusion.
After much investigation and many suggestions, I was able to isolate the issue to the MPS, a rebuilt 0280100043 unit, remanufactured by Fuel Injection Corp USA and sold by Rich Bontempi's High Performance House back in 2020. Last fall, I was able to get the car running, idling great and driving spottily by simply using the Tangerine Racing MPS tuning kit to adjust the inner idle screw richer, but was never able to achieve full throttle. I ended up cranking the inner screw up to max, and was able to get about 60% throttle before the engine would die. Although idle became excessively rich, this made the car driveable enough to get it hot. Especially since nearing the cut-out point, it seemed to get very lean.
With the warmer weather back, I've been working on trying to tune the car in better, but have been met without much success. But I've dialed in with growing specificity toward what seems to be an MPS transformer problem.
I started by doing a full intake system rebuild/re-seal, just to be certain I wasn't fighting a vacuum leak. Slowly and carefully cleaning and re-seating all mating surfaces and using gasket dressing on gaskets. (I also 3D scanned and modeled the intake system, but that's a topic for another thread.) I'm now up to 100% confident that the car has no vacuum leaks, up from maybe 85-90% before.
Then I set about adjusting the tuning. I got a proper vacuum pump that could pull up to 25+ inHg and bench tested my MPS. Like last time, the 8-10 coil (secondary) curve came in FAR lower than both the graph value and chart values given on Brad Ander's MPS page, at least on the high-power end of the scale, with the primary coil being around 1/2 the secondary. [Graphs and chart shown below.]
With the inner screw maxed out, the 25inHg primary inductance secondary 0.67H and the primary 0.32H. At 0inHg, the secondary approaches .93H and the primary, .49H.
Now, I had posted this very low inductance curve in my last thread, and the community consensus was that the shape of the curve was more important than the actual values, but I question this, and wanted to test where the cutout point on my engine's throttle response was, so I hooked a vacuum gauge up to a long hose, plugged it into the manifold port where the decel valve usually goes, and went for a drive.
After letting the engine get hot, I did a few pulls, where I gradually increased my throttle position and watched the vacuum.
Sure enough, the engine would cut out each time the manifold vacuum fell below about 7-8inHg on the gauge, which is just past the intercept point between my MPS's secondary curve, and the 043 curve Brad has posted on his site.
This aligned well enough with my suspicions that I was willing to spend the money to test out another unit. I went out looking, and settled on a 0280100037 unit from EBS Racing, since I couldn't find any verified '043s, and '037s are compatible with my car/ECU - considered to be an "upgrade" due to their higher stock mixture setting.
When this one arrived, I found it had also been remanufactured by Fuel Injection Corp. And upon testing its coils, while the curve's shape looked much healthier than my '043's, it was similarly very low. And sure enough, the car wouldn't start on it. What's more, I found that on this unit, the inner adjustment screw was nearly maxed out already, only about a quarter turn from its limit.
At this point, I'm scratching my head a bit. Could I really have gotten 2 bad rebuilds in a row? Does the inductance value really not matter, and there's something else wrong with my car? Why are my values both so different than the nominal ones Brad measured?
I checked that my LCR meter isn't bad with a 2.2H coil from DigiKey, and it read that more or less dead on. I also pulled the top off my '043 and checked to see that the transformer actuation is free and clear. Even with the core pulled to its limit, the secondary won't go much above 1.0H. The resistances in the coils are correct, so they're not shorted. All I can think is maybe the cores have been replaced with something non-suitable?
I know Jeff drove his car with my components last summer, which is further confusing, though I don't know if he tried full throttle or not, and I know my 2056 pulls a little less vacuum than an engine with a stock cam.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-27426-1713200815.1.png)
Values:
Brad Ander's 043 (based on 2 rebuilt and 1 NOS unit)
0 inHg = 1.39H
4 inHg = 1.18H
15 inHg = 0.71H
My Rebuilt 043
0 inHg = 0.929H
4 inHg = 0.915H
15 inHg = 0.809H
Brad Ander's 037 (based on 1 rebuilt unit)
0 inHg = 1.44H
4 inHg = 1.26H
15 inHg = 0.72H
My Rebuilt 043
0 inHg = 0.943H
4 inHg = 0.883H
15 inHg = 0.601H
So I guess, I'd like to ask the forum a favor. Anyone who has an LCR meter and a WORKING D-Jetronic car, if you're willing, do me a favor and check the inductance across your 8-10 coil with no vacuum, and post it here. If you feel like graphing your response curve, all the better!
ChrisFoley
post Aug 18 2024, 05:13 AM
I am Tangerine Racing
Here's the latest news:
I ran out of diaphragms last month. My supplier of Be-Cu stampings isn't going to make them for me anymore. It was 8 years since my last order of 250 pcs.
I may not have any new kits available for the remainder of 2024, until I work out a new plan. Right now I'm looking into an alternate material created to replace Be-Cu with a non-toxic alloy.
The material I found is also a copper alloy, with similar flexural properties after heat treat.
rjames
post Aug 18 2024, 09:45 AM
I'm made of metal
QUOTE(ChrisFoley @ Aug 18 2024, 04:13 AM) *
Bummer. I really appreciate you making these in the first place. I have 2 MPSs rebuilt with your diaphragms- one in the car, and one as a spare. Even though I don't need another diaphragm, I'd happily preorder one or two if it helps make a new batch happen.
Cessnaporsche01   MPS Inductance Curves and Tuning   Apr 15 2024, 11:06 AM
rjames   Just my $.02, from my experience: The LCR met...   Apr 15 2024, 11:33 AM
Cessnaporsche01   Just my $.02, from my experience: The LCR me...   Apr 15 2024, 11:47 AM
rjames   [quote name='rjames' post='3139717' date='Apr 15 ...   Apr 15 2024, 12:01 PM
Cessnaporsche01   Yeah, apologies. I meant the full load stop when I...   Apr 15 2024, 12:20 PM
rjames   Yeah, apologies. I meant the full load stop when ...   Apr 15 2024, 12:51 PM
Superhawk996   My recollection from the original thread was that ...   Apr 15 2024, 12:58 PM
Cessnaporsche01   My recollection from the original thread was that...   Apr 15 2024, 02:52 PM
emerygt350   I agree with superhawk. My build actually produce...   Apr 15 2024, 02:57 PM
Cessnaporsche01   I agree with superhawk. My build actually produc...   Apr 15 2024, 03:19 PM
Olympic 914   http://www.914world.com/bbs2/uploads_offsite/i...   Apr 15 2024, 06:48 PM
brant   Innovate AFR up the tail pipe No dyno needed Drive...   Apr 15 2024, 07:40 PM
adolimpio   It may be my simple mind, but it seems that someth...   Apr 15 2024, 07:46 PM
brant   The meter gives you a curve. For a hypothetical m...   Apr 15 2024, 07:57 PM
r_towle   I wonder what material was used for the diaphragm   Apr 15 2024, 08:20 PM
brant   Beryllium copper Lots of old threads about this Do...   Apr 15 2024, 08:33 PM
r_towle   Exactly my point   Apr 15 2024, 11:19 PM
JamesM   So I guess, I'd like to ask the forum a favo...   Apr 16 2024, 01:57 AM
emerygt350   Those vacuum numbers look good to me. I pull 20 a...   Apr 16 2024, 02:05 AM
ChrisFoley   I have examples of FIC diaphragms in my office. Th...   Apr 16 2024, 04:40 AM
worn   I have examples of FIC diaphragms in my office. T...   Aug 17 2024, 06:59 PM
Cessnaporsche01   Thanks for the input, all! Olympic, I'll ...   Apr 16 2024, 06:45 AM
TJB/914   Thanks for the input, all! Olympic, I'll...   Apr 16 2024, 07:27 AM
emerygt350   Don't discount those trigger points. That cou...   Apr 16 2024, 01:53 PM
FlacaProductions   The 123 really is the most fabulous thing... Don...   Apr 16 2024, 02:14 PM
adolimpio   Has anyone considered checking the TPS? If not wo...   Apr 16 2024, 08:13 PM
emerygt350   Yes, a good idea. You can check that without remo...   Apr 17 2024, 04:19 AM
rick 918-S   Here is a dumb question... Have you checked your f...   Apr 17 2024, 05:46 AM
Cessnaporsche01   TJB, thanks for the offer. I'm going with Olym...   Apr 17 2024, 02:56 PM
Cessnaporsche01   Well dang. I can rule out the MPS as the root caus...   Apr 20 2024, 10:04 AM
Superhawk996   I was taking CHT measurements at from the harness...   Apr 20 2024, 11:16 AM
Cessnaporsche01   I was taking CHT measurements at from the harnes...   Apr 20 2024, 12:02 PM
Superhawk996   [quote name='Superhawk996' post='3140494' date='A...   Apr 20 2024, 12:15 PM
technicalninja   :agree: :agree: :agree: :agree: If I found a ...   Apr 20 2024, 12:45 PM
windforfun   :agree: :agree: :agree: :agree: If I found a...   Apr 21 2024, 04:14 PM
Ishley   Listening to your car run.... have you changed out...   Apr 21 2024, 09:26 AM
Cessnaporsche01   I did some testing for resistance around the car t...   Apr 21 2024, 11:16 AM
Superhawk996   All the metal is quite clean, so I don't know...   Apr 21 2024, 11:32 AM
Superhawk996   As an aside, listening to your video I’m not co...   Apr 21 2024, 11:37 AM
Cessnaporsche01   Fair enough on the resistance thing. I doubt a few...   Apr 21 2024, 03:26 PM
Superhawk996   Fair enough on the resistance thing. I doubt a fe...   Apr 21 2024, 07:34 PM
emerygt350   During this troubleshooting I would disconnect bot...   Apr 21 2024, 04:29 PM
Superhawk996   During this troubleshooting I would disconnect bo...   Apr 21 2024, 07:27 PM
emerygt350   When I was troubleshooting my 914 I ran grounds fr...   Apr 22 2024, 05:14 AM
ChrisFoley   Here's the latest news: I ran out of diaphragm...   Aug 18 2024, 05:13 AM
JeffBowlsby   Here's the latest news: I ran out of diaphrag...   Aug 18 2024, 08:21 AM
rjames   Here's the latest news: I ran out of diaphrag...   Aug 18 2024, 09:45 AM
emerygt350   That is too bad. I hope you can find a new alterna...   Aug 18 2024, 06:23 AM
davep   Chris, I hope that you can get a new supply of dia...   Aug 18 2024, 09:49 AM
914_teener   Chris, I hope that you can get a new supply of di...   Aug 18 2024, 01:09 PM
- Lo-Fi Version Time is now: 3rd September 2025 - 07:49 PM
