| Literati914 |
Aug 19 2024, 05:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,312 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I installed a CHT gauge on my project car and ran wiring, but didn't bother to install the sender ring under the #3 spark plug before installing the engine (IMG:style_emoticons/default/rolleyes.gif) .. basically because I didn't want to remove the induction system and tin, etc. on an engine that I'd not planned to keep for very long. But lately, I've been thinking it'll be longer on this engine than I'd originally planned - and having the CHT hooked up would be nice.
I've run the wiring into the engine compartment (not sure but I think most run it under the tin, no?). So anyway - can I just bend the 14mm sender ring so that the wire come up vertically thru the tin (under the spark plug boot), and slip the ring on before installing the #3 plug? Or is that not gonna work? |
| FlacaProductions |
Aug 19 2024, 07:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,192 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I took off the washer, bent the CHT sender so the wire had a natural 90 degree exit back out the plug hole and it works just fine - even after another recent plug change. No issues.
Literati914 CHT sender install without removing tin? Aug 19 2024, 05:22 PM
VaccaRabite You are over thinking it.
Jut pull the washer off ... Aug 19 2024, 06:01 PM
emerygt350 Yep. Just make sure it's on flush and your plu... Aug 19 2024, 06:18 PM
Literati914
Jut pull the washer off... Aug 19 2024, 06:28 PM
Literati914
Yep. Just make sure it's on flush and your pl... Aug 19 2024, 10:20 PM
emerygt350
Yep. Just make sure it's on flush and your p... Aug 20 2024, 04:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 05:34 AM |
