> CHT sender install without removing tin?
Literati914
post Aug 19 2024, 05:22 PM
I installed a CHT gauge on my project car and ran wiring, but didn't bother to install the sender ring under the #3 spark plug before installing the engine (IMG:style_emoticons/default/rolleyes.gif) .. basically because I didn't want to remove the induction system and tin, etc. on an engine that I'd not planned to keep for very long. But lately, I've been thinking it'll be longer on this engine than I'd originally planned - and having the CHT hooked up would be nice.
I've run the wiring into the engine compartment (not sure but I think most run it under the tin, no?). So anyway - can I just bend the 14mm sender ring so that the wire come up vertically thru the tin (under the spark plug boot), and slip the ring on before installing the #3 plug? Or is that not gonna work?
Literati914
post Aug 19 2024, 10:20 PM
QUOTE(emerygt350 @ Aug 19 2024, 07:18 PM) *
Yep. Just make sure it's on flush and your plug is fully seated. If it's not fully seated it will read cool, by quite a bit.
QUOTE(FlacaProductions @ Aug 19 2024, 08:47 PM) *
I took off the washer, bent the CHT sender so the wire had a natural 90 degree exit back out the plug hole and it works just fine - even after another recent plug change. No issues.
Thanks for confirmation on this, I'm gonna try and keep it simple..
emerygt350
post Aug 20 2024, 04:44 AM
QUOTE(Literati914 @ Aug 19 2024, 10:20 PM) *
Cutting the head just makes plug removal easy. With out the cut you must be careful when playing with that plug, but it does work fine.
- Lo-Fi Version Time is now: 2nd May 2026 - 05:34 AM
