> Rear Brake Rotors
yeahmag
post Aug 20 2024, 03:39 PM
I accidentally purchased (who knows how) 911 rear discs (SEB-205195C) instead of the 914-6 discs (SEB-105184C) I typically use. I run late 914-4 front calipers on the rear with a bias valve. I assume there is no way these will fit... Correct?
911 SC rotor
Diameter: 290mm
Type: Internally vented
Brake Disc Thickness: 20mm
vs
914-6 rotor
Diameter: 286mm
Thickness: 10.5mm
dr914@autoatlanta.com
post Aug 21 2024, 09:34 AM
and the offset is different as well
QUOTE(yeahmag @ Aug 20 2024, 02:39 PM) *
911 SC rotor
Diameter: 290mm
vs
914-6 rotor
Diameter: 286mm
Thickness: 10.5mm
- Lo-Fi Version Time is now: 15th April 2026 - 08:00 AM
