| TINKERGINEERING |
Jul 29 2024, 01:56 PM
Member ![]() ![]() Group: Members Posts: 230 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California
Ok so brake lines are next in my restoration. Is it a good idea to try and bend my own stainless steel brake lines? There is probably a thread already on this, but I haven't found it (Let me know if there indeed is one). But have any of you had success with this? Drop any tips below
thanks- Frances |
| bdstone914 |
Jul 29 2024, 03:38 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Stainless steel is not needed or easy to form the ends. I have formed a few from straight lunes from FLAPS. One thing to watch for are the fittings. The lines from FLAPS do not have full thread like original lines. I had one nearly stripped out the threads in an aluminum caliper.
I woyld hit the easy button and buy a set from PMB |
| bkrantz |
Jul 29 2024, 07:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Stainless steel is not needed or easy to form the ends. I have formed a few from straight lunes from FLAPS. One thing to watch for are the fittings. The lines from FLAPS do not have full thread like original lines. I had one nearly stripped out the threads in an aluminum caliper. I woyld hit the easy button and buy a set from PMB And be warned that stainless lines are a beech to get to seal at all the fittings. I had to crank down all the fittings WAY more than than I ever did for mild steel lines, and even then it took several tries for one joint. |
| fixer34 |
Jul 30 2024, 06:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,406 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Stainless steel is not needed or easy to form the ends. I have formed a few from straight lunes from FLAPS. One thing to watch for are the fittings. The lines from FLAPS do not have full thread like original lines. I had one nearly stripped out the threads in an aluminum caliper. I woyld hit the easy button and buy a set from PMB And be warned that stainless lines are a beech to get to seal at all the fittings. I had to crank down all the fittings WAY more than than I ever did for mild steel lines, and even then it took several tries for one joint. I initially ordered some stainless lines but sent them back for the steel ones. As noted above, had ones I could not get to seal without tightening down more than I was comfortable with. Since there are no gaskets/washers involved, a good seal requires the ends to 'crush' a little. The big advantages to stainless are corrosion resistance and much higher braking pressures. Unless you plan to take yours swimming in the ocean or do regular panic stops, steel lines are all you need. |
| bkrantz |
Aug 21 2024, 07:22 PM
Stainless steel is not needed or easy to form the ends. I have formed a few from straight lunes from FLAPS. One thing to watch for are the fittings. The lines from FLAPS do not have full thread like original lines. I had one nearly stripped out the threads in an aluminum caliper. I woyld hit the easy button and buy a set from PMB And be warned that stainless lines are a beech to get to seal at all the fittings. I had to crank down all the fittings WAY more than than I ever did for mild steel lines, and even then it took several tries for one joint. I initially ordered some stainless lines but sent them back for the steel ones. As noted above, had ones I could not get to seal without tightening down more than I was comfortable with. Since there are no gaskets/washers involved, a good seal requires the ends to 'crush' a little. The big advantages to stainless are corrosion resistance and much higher braking pressures. Unless you plan to take yours swimming in the ocean or do regular panic stops, steel lines are all you need. If I did it over again, I would do what you did. And I agree that for our typical use, Stainless is overkill. |
TINKERGINEERING Brake Lines Jul 29 2024, 01:56 PM
Shivers
Ok so brake lines are next in my restoration. Is ... Jul 29 2024, 02:12 PM
fixer34
Ok so brake lines are next in my restoration. Is ... Jul 29 2024, 02:16 PM
technicalninja :agree: :agree: :agree: Jul 29 2024, 02:16 PM
friethmiller :agree:
I went with the Stainless from PMB. Jul 29 2024, 02:22 PM
Chris914n6 Suprisingly Autozone sells all the pieces to DIY b... Jul 29 2024, 03:10 PM
Maltese Falcon 914 uses a spec 'Double flare at the ends= whi... Jul 29 2024, 07:56 PM
technicalninja Frances,
Having the skill to create high pressure ... Jul 29 2024, 08:04 PM
technicalninja Double post, sorry! Jul 29 2024, 08:05 PM
Superhawk996 +1 steel lines and buy them. Bubble flares aren’... Jul 30 2024, 07:48 AM
worn
+1 steel lines and buy them. Bubble flares arenâ€... Aug 21 2024, 08:58 PM
mepstein You and Eric are buddies. I can’t imagine why yo... Jul 30 2024, 08:17 AM
Robarabian Frances,
You did me a solid on a contest a while ... Jul 30 2024, 10:31 PM
Frances,
You did me a solid on a contest a while... Jul 31 2024, 05:18 AM
76-914 I'm going to play the Devil's Advocate her... Jul 31 2024, 08:15 AM
Superhawk996
I'm going to play the Devil's Advocate he... Jul 31 2024, 08:25 AM
76-914
I'm going to play the Devil's Advocate h... Aug 20 2024, 09:38 PM
VaccaRabite While I generally will back Eric/PMB - this time I... Jul 31 2024, 08:58 AM
Dave_Darling Perhaps another visit with PMB is in order? That ... Jul 31 2024, 05:57 PM
mepstein :) Jul 31 2024, 06:23 PM
Add one more line
$500 per hour if... Jul 31 2024, 07:13 PM
TINKERGINEERING Haha thanks guys! I took a break from thinking... Aug 20 2024, 09:02 PM
willieg IMHO, Copper nickel brake lines are much easier to... Aug 20 2024, 10:00 PM
worn
IMHO, Copper nickel brake lines are much easier t... Aug 21 2024, 08:59 PM
Cairo94507 I bought a complete set of Eric's "green... Aug 22 2024, 08:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:33 PM |
