| oakdalecurtis |
Aug 23 2024, 10:30 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,401 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I'm taking my mint 76 914 to a race friend specialist Monday. The brake pedal lately seems to go too far before braking effect. The master cylinder reservoir shows no sign of loss of fluid, nor do I see any sign of brake fluid on the garage floor. The brake pads seem like they have life left. I don't drive it a lot, and it has been ages since I think the pads were replaced, but again, they look ok. I have never changed the brake fluid, figuring if it ain't broke...
Would anyone hazard a guess based on these facts on where we might look first? |
| Jack Standz |
Aug 24 2024, 09:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 730 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Let's see what your race friend says.
But, maybe you need a new master cylinder. And if/when you replace the MC, flush out the old fluid well. Going forward, put flushing the brake fluid on your annual maintenance schedule. |
oakdalecurtis Excessive brake pedal movement noted Aug 23 2024, 10:30 PM
willieg Sounds like air in the system. Or faulty master c... Aug 23 2024, 10:57 PM
emerygt350 Brake fluid picks up water just sitting there, you... Aug 24 2024, 04:14 AM
technicalninja I'd adjust rear caliper "venting" an... Aug 24 2024, 07:21 AM
Shivers E-brake adjustment at the caliper? :idea: Aug 24 2024, 07:23 AM
technicalninja The Allens under the caps set caliper piston depth... Aug 24 2024, 07:31 AM
Superhawk996
The Allens under the caps set caliper piston dept... Aug 24 2024, 11:02 AM
brant Always flush your brake fluid every other year Aug 24 2024, 08:26 AM
brant
But,... Aug 24 2024, 10:49 AM
914_teener My thoughts are that you need to think about preve... Aug 24 2024, 01:28 PM
emerygt350 Rear venting isn't bad once you have pmb rebui... Aug 24 2024, 05:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 06:48 PM |
