| oakdalecurtis |
Aug 23 2024, 10:30 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,401 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I'm taking my mint 76 914 to a race friend specialist Monday. The brake pedal lately seems to go too far before braking effect. The master cylinder reservoir shows no sign of loss of fluid, nor do I see any sign of brake fluid on the garage floor. The brake pads seem like they have life left. I don't drive it a lot, and it has been ages since I think the pads were replaced, but again, they look ok. I have never changed the brake fluid, figuring if it ain't broke...
Would anyone hazard a guess based on these facts on where we might look first? |
| 914_teener |
Aug 24 2024, 01:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
My thoughts are that you need to think about preventative maintenance for yourself.
Oil Fuel Brake Fluid Probably in this order. It is vital to also at least exercise the car every few months and the reason is if the fluid has absorbed some water it will or can oxidize the piston bores causing the pistons to stick. The maintenance period for brake fluid is 2 years. In my Cayman and since I depended on it to stop the car, a very big deal. Later it can be very expensive if you ignore doing it. The rear venting gap is somewhat of a pain to do but once set, you normally don't set them often if you don't do a lot of driving. That is something if you've never done it before you might need help with. Suggest you may want to change your mindset and mantra about routine maintenance. You asked for thoughts. |
oakdalecurtis Excessive brake pedal movement noted Aug 23 2024, 10:30 PM
willieg Sounds like air in the system. Or faulty master c... Aug 23 2024, 10:57 PM
emerygt350 Brake fluid picks up water just sitting there, you... Aug 24 2024, 04:14 AM
technicalninja I'd adjust rear caliper "venting" an... Aug 24 2024, 07:21 AM
Shivers E-brake adjustment at the caliper? :idea: Aug 24 2024, 07:23 AM
technicalninja The Allens under the caps set caliper piston depth... Aug 24 2024, 07:31 AM
Superhawk996
The Allens under the caps set caliper piston dept... Aug 24 2024, 11:02 AM
brant Always flush your brake fluid every other year Aug 24 2024, 08:26 AM
Jack Standz Let's see what your race friend says.
But, ... Aug 24 2024, 09:58 AM
brant
But,... Aug 24 2024, 10:49 AM
emerygt350 Rear venting isn't bad once you have pmb rebui... Aug 24 2024, 05:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 06:50 PM |
