| SWH |
Aug 25 2024, 09:09 PM
Newbie ![]() Group: Members Posts: 16 Joined: 27-April 24 From: Arizona Member No.: 28,084 Region Association: Southwest Region |
I have rebuilt my 2.0L and am down to mating trans to motor. When I did this I noticed I have no free play in the t/o bearing arm. I have measured and does not appear to be pressing the pressure plate fingers but is on them. Is that acceptable? I expected to have some level of free movement in the arm. Is there something else I can check? Flywheel, clutch disc, pressure plate and Throwout bearing are all new. Crank, flywheel and pressure plate was balanced at machine shop. Except for the flywheel that was completely shot all measurements on new parts
Thanks, |
| SWH |
Aug 26 2024, 04:43 PM
The pivot bolt behind the fork had 1 flat and 3 spring washers. I went down to just the flat washer and how have 1/4 free play. Thanks
SWH No clutch free play Aug 25 2024, 09:09 PM
barefoot Put a thick washer under the throwout pivot, see i... Aug 26 2024, 06:44 AM
Dr Evil
Put a thick washer under the throwout pivot, see ... Aug 26 2024, 04:46 PM
Shivers I had 6 vw bugs and a van before I got my 914. Whe... Aug 26 2024, 08:16 AM
worn
I have rebuilt my 2.0L and am down to mating tran... Aug 26 2024, 02:45 PM
930cabman
The pivot bolt behind the fork had 1 flat and 3 s... Aug 27 2024, 05:38 PM
Dr Evil The only way for the space between the TOB and pre... Aug 26 2024, 04:53 PM
porschetub
I have rebuilt my 2.0L and am down to mating tran... Aug 27 2024, 01:56 PM
rfinegan iI the Pressure plate sticking on the locator pins... Aug 28 2024, 08:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 09:55 AM |
