| Chaznaster |
Aug 29 2024, 07:23 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States
Hi All.
I am having a trouble starting my carbureted 1.8 when the engine is up to temperature (heads at 310 degrees for over 30min). The engine is definitely turns over and the starter engages. The car starts immediately when cool/ cold. It is also fine when I let it cool after being hot. My battery seems to have settled out at about 12.2V. Per the Google, that equates to 60% useful charge. That is definitely a problem. My theory on the non-hot start is that, as copper wire resistance increases with increasing temperature (also something learned on Google), it is just not getting enough current to the coil when hot. Cold wires = lower resistance = better current flow, and so, even with the marginal battery, it gets enough juice to start. Now on to why the battery is running low. At warmed-up idle speed (800-900 RPM), the multimeter only reads 12.3. That is most certainly the cause of the low voltage. I'd very much like your input as to whether this is likely caused by a voltage regulator problem or an alternator problem (or both). EDIT: It will always start with a push start ... Many thanks! |
| davep |
Aug 31 2024, 03:28 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,377 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Use a decent battery charger to bring the battery up to full charge. Report back what the battery voltage settles to after a few hours off of the charger. Proper voltage is about 12.8V. As Peter says, when cranking off of the battery the voltage will drop drastically, and a weak battery will drop even further. If you have a battery at 60% it will soon leave you stranded.
As Mark says, check the alternator harness. I checked out 10 or 12 harnesses not long ago and every one was bad! Read this thread also: http://www.914world.com/bbs2/index.php?showtopic=371628 |
Chaznaster Battery Voltage Low - most likely culprit? Aug 29 2024, 07:23 PM
fixer34
Hi All.
I am having a trouble starting my carbur... Aug 29 2024, 08:17 PM
emerygt350 I am a fan of the adjustable digital voltage regul... Aug 30 2024, 05:00 AM
914Sixer Often missed item is the alternator wiring harness... Aug 30 2024, 06:22 AM
brant You have adequate voltage to turn the starter
You ... Aug 30 2024, 06:31 AM
930cabman
Hi All.
I am having a trouble starting my carbur... Aug 30 2024, 01:33 PM
Chaznaster Thanks everyone - this is all really helpful and g... Aug 30 2024, 06:42 PM
emerygt350
Thanks everyone - this is all really helpful and ... Aug 31 2024, 05:23 AM
Superhawk996
EDIT: It will always start with a push start ..... Aug 31 2024, 06:23 AM
Spoke
At warmed-up idle speed (800-900 RPM), the multim... Aug 31 2024, 04:42 PM
Chaznaster Tons of great ideas here - thank you all. I'll... Sep 2 2024, 06:24 AM
930cabman
Tons of great ideas here - thank you all. I'l... Sep 2 2024, 07:09 AM
Spoke
In the meantime, by checking the alternator harne... Sep 2 2024, 07:16 PM
Dave_Darling The engine needs three things to run: Fuel, Air, ... Sep 3 2024, 05:30 PM
Chaznaster I am back with some data ...
Battery after full c... Sep 4 2024, 05:16 PM
Spoke
Battery after full ... Sep 6 2024, 08:00 PM
Chaznaster Giving it some thought, I would probably conclude ... Sep 6 2024, 06:15 PM
emerygt350 Replacing the VR is so easy and cheap, it might as... Sep 6 2024, 06:33 PM
Superhawk996
Replacing the VR is so easy and cheap, it might a... Sep 6 2024, 07:14 PM
Chaznaster I got back to the car today and retook measurement... Sep 9 2024, 04:51 PM
Spoke
I got back to the car today and retook measuremen... Sep 9 2024, 07:55 PM
Chaznaster
[quote name='Chaznaster' post='3166552' date='Sep... Sep 10 2024, 06:13 PM
Spoke
When I go from 1400 to 850 D+ does go back to 0.6... Sep 11 2024, 06:53 AM
Chaznaster
When I go from 1400 to 850 D+ does go back to 0.... Sep 12 2024, 04:38 PM
rhodyguy Starts fine when cold? When it’s hot it still sp... Sep 9 2024, 05:44 PM
Chaznaster
Starts fine when cold? When it’s hot it still s... Sep 10 2024, 06:11 PM
emerygt350 You want 13.5 at idle. After I switched to a mode... Sep 9 2024, 05:50 PM
iankarr Just dealt with this on my green car. Replaced the... Sep 10 2024, 11:52 PM
Chaznaster
Just dealt with this on my green car. Replaced th... Sep 12 2024, 04:37 PM
Chaznaster So ... I feel a bit foolish about this ... the cau... Sep 17 2024, 02:48 PM
emerygt350
So ... I feel a bit foolish about this ... the ca... Sep 18 2024, 01:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 11:31 PM |
