> Valves need adjustment?
Mikemo44
post Sep 1 2024, 04:14 PM
Hi All, Long story short, I bought a 914 with two turbos strapped to the back and a Holley EFI installed. It never ran well so I decided ditch the turbos and try carbs. Prior to installing the carbs, I took a shot at adjusting the valves as I thought that might be contributing the car running rough.
Now with the carbs installed, it seems the valves in cylinder 2 are off. Lots of knocking and exhaust coming out of the cylinder 2 carbs.
Is this a valve adjustment issue? Or something else like timing?
Much appreciate the help.
https://www.youtube.com/watch?v=tzSmoiLO8mc
technicalninja
post Sep 1 2024, 04:39 PM
Compression test.
Leak down if trouble seen in comp test.
Possibly correct valve adjustment???
recheck comp/leak down tests
You have what looks like intake valve not seating correctly on cyl #2 to me.
My money is on wounded engine, but you might get lucky...
I'd LOVE to see the twin turbo set up on that.
It would need tiny little turbos.
4 head bolt air cooled design is less than ideal with boost, but a mild system done perfectly might do OK.
Two baby turbos would be interesting...
- Lo-Fi Version Time is now: 8th December 2025 - 05:10 AM
