| Mikemo44 |
Sep 1 2024, 04:14 PM
Newbie ![]() Group: Members Posts: 9 Joined: 26-August 23 From: Chicago Member No.: 27,543 Region Association: None |
Hi All, Long story short, I bought a 914 with two turbos strapped to the back and a Holley EFI installed. It never ran well so I decided ditch the turbos and try carbs. Prior to installing the carbs, I took a shot at adjusting the valves as I thought that might be contributing the car running rough.
Now with the carbs installed, it seems the valves in cylinder 2 are off. Lots of knocking and exhaust coming out of the cylinder 2 carbs. Is this a valve adjustment issue? Or something else like timing? Much appreciate the help. https://www.youtube.com/watch?v=tzSmoiLO8mc |
| Mikemo44 |
Sep 2 2024, 09:43 AM
Thanks, all. I will run some tests next weekend before dropping the engine. I had the engine out last winter and replaced just about every gasket/seal I could. I'm definitely a novice and didn't pay much attention to the valves and the cylinder heads.
Here is the bring a trailer link to the car I bought. 3rd owner in 3 years...should have figured it was problematic. 914TT |
Mikemo44 Valves need adjustment? Sep 1 2024, 04:14 PM
technicalninja Compression test.
Leak down if trouble seen in co... Sep 1 2024, 04:39 PM
emerygt350 I would love to see it too, but a dropped seat in ... Sep 1 2024, 04:48 PM
930cabman :wttc:
Hate to say, but she doesn't sound go... Sep 1 2024, 05:30 PM
JamesM You traded Holly EFI for carbs?
:huh: Sep 1 2024, 06:43 PM
cgnj Lazy man's way.
Leak down. It will tell you w... Sep 1 2024, 09:55 PM
emerygt350 A quick snoop with an boro/endoscope after the com... Sep 2 2024, 05:25 AM
burton73 Welcome to 914world ra great place for you to get ... Sep 2 2024, 10:04 AM
Superhawk996 Check your spark plug wire routing. Black wires a... Sep 2 2024, 10:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 05:09 AM |
